Compression Artifacts / Errors
1497 12 2015-9-18
ilkercanikligil
Turkey
Following is the short clip of original footage shot (4K) with Phantom 3 Pro firmware 1.2.6
https://www.dropbox.com/s/4f1a5f ... onartifact.mp4?dl=0
There is a very strange compression error seen on the left side of the screen. Although I understand 60 Mbit is very low for 4K. This one seems like an obvious bug to me.
Any idea?
2015-9-18
ag0n
Flight distance : 700846 ft
Not seeing it here, but I normally can't play 4K video on this computer and this one played fine.
2015-9-18
ksunsingh
if you're referring to the jumping action of the cloud reflection (?)
i see it, no idea what could cause it
2015-9-18
ilkercanikligil
Turkey
yes exactly. it jumps every 8th frame. which shows a compression error.
2015-9-19
ilkercanikligil
Turkey
I mailed DJI about this. But somehow service staff is clueless about this technology. After several mails asking me to try with other PC's etc (which is obviously irrelevant) today I'vegot an email about taking my drone to local service and it will be repaired!!
I dont know how a compression error/bug can be repaired : )
2015-9-23
nickcb
Is it due to a to fast a shutter speed and how the frames play back?
2015-9-23
ilkercanikligil
Turkey
No the shutter speed was not fast. An ND filter was on. It can't be a playback error either. I did not recompress or edit the file. The effect is clearly visible on individual frames when paused.
This probably comes from bad compression algorithm and low bitrate for 4K.
It is sad because Phantom 3 is a fantastic platform with an awful compressor chip.
2015-9-23
levreault
Flight distance : 489111 ft
I've seen the same issue with cloud shadows. Because of it I quit flying on partly sunny days. I THINK the 1.4.010 update resolved that issue, but I can't say for sure because I have so little partly sunny footage since this:
2015-9-28
CapitAn
Mine does this badly too, and l'm still at 1.1.6.
The shadows jump all over the place in back-to-back clips in this video l did early morning (shadows are long).
lf you don't want to endure the whole thing, the shadows start at 2:45.
2015-9-28
Mad_Angler1
Flight distance : 2741657 ft
Its a known limitation of the codec and its the same in the Inspire 1,  its due to a lack of B frames in the codec,
have a read of http://www.streaminglearningcent ... verview.html?page=4
There has been a LOT of discussion around this on the I1 forums and RCG,
Search Inspire 1 B Frames
2015-9-28
ilkercanikligil
Turkey
Mad_Angler1 Posted at 2015-9-29 01:01
Its a known limitation of the codec and its the same in the Inspire 1,  its due to a lack of B frame ...
thanks for the info. but isnt it funny that DJI wants me to send the drone back to china to repair it?
2015-10-3
Mad_Angler1
send it in and see what happens , all i provided was info regarding common know limitations of the current system, your may not be the same
2015-10-3
ilkercanikligil
Turkey
Mad_Angler1 Posted at 2015-10-3 17:03
send it in and see what happens , all i provided was info regarding common know limitations of the c ...
I don't trust them and somehow I tried it with the new firmware and I couldnt replicate the error.
strange
2015-10-5
