Ipad mini 4 (native IOS9) & IOS 9.0 updates. Issues or not?
3432 14 2015-9-18
LeHussard
Flight distance : 297523 ft
I just changed my mini 2 wifi for a mini 4 wifi+cellular today.Very nice, small and powerfull.
But i see he is with IOS 9.0.
I saw on this forum some people experiencing some issues with IOS 9 update on Ipad mini 2 or 3 and The DJI GO app.
In my case, i tried, without propellers, and seems to work very fine and smooth.(firmware v1.4.0010)
Stable signal everything seems ok.
Don't have tryed a fly for now...
Any experiences?
Multiple choiceVote: ( Up to 2 entry optional ), Total 48 people participate in voting
Your user group with no voting privileges
2015-9-18
gregg1r
None of the above. I installed IOS9 on mini3. Using Pilot app 1.1.2 and no problems. Didn't want to update to IOS9 but it was a late nite and I'm getting tired of all the notices to upgrade this or that.
2015-9-18
millernascar48
Ios 9 does not work much past 2200 feet (lose video feed) when I was on 8.4 5000 to 6000 feet was easy to do at 400 feet high...also I did notice the red arrow in the flight log does not move now also....so i,m sure dji will wait till ios 9.1 comes out in Nov before they will update the problem...so back in the case it goes till DJI updates the GO APP...;(
2015-9-19
dreadwing
Flight distance : 5130955 ft
millernascar48@ Posted at 2015-9-19 11:41
Ios 9 does not work much past 2200 feet (lose video feed) when I was on 8.4 5000 to 6000 feet was ea ...
I have the same issue with the map arrow not following the path in the log playback. Hope they sort that out soon.
2015-9-19
stang7tl
DAMN IT I just got this drone with one flight down and my phone updated to IOS 9 and drone won't fly. it has no LED flash at all and just beeps really loud. The app says overall stats aircraft needs update
2015-9-19
LeHussard
Issue found with mini4 and DJI GO in the flight simulator. Lagging and freezing when switching to intelligent modes. Then app crash..
2015-9-20
Sir Edward K
Why can't you just revert back to the 8.4.1 version.  Apple still has it signed for install so you can go back that version.  I also saw where either DJI Dave or Tim said that an update for the GO App should be ready in 2 to 3 weeks.
Until then.
iOS 9 Revert back to iOS 8.4.1
2015-9-21
apocnz
Flight distance : 106588 ft
Yup just revert back to 8.4. That's what I did.
It's not the end of the world.
2015-9-21
Ncgo4
If you've upgraded an IOS device to v9 you can revert back.  However, if you buy a Mini 4 it come with IOS9 and cannot be downgraded to an earlier version.  I was told this at the Apple Store,
2015-9-21
aopisa
Flight distance : 430686 ft
Ncgo4 Posted at 2015-9-21 19:11
If you've upgraded an IOS device to v9 you can revert back.  However, if you buy a Mini 4 it come wi ...
That's my situation. I am hoping all will be trouble free.
2015-9-21
Phuglie
Flight distance : 45226 ft
I don't seem to have an issue with iOS 9.0.1 - but always fly LOS (line of sight).
Je ne vois pas de problème  liés à iOS 9.0.1 ? Et en plus, je ne perds pas mon drone de vue !
2015-9-30
BRENT1956
Flight distance : 3686975 ft
Phuglie Posted at 2015-9-30 03:01
Je ne vois pas d ...
Has Director disappeared too? Never really used it but cannot see it anywhere? Any clues? I can get to templates and videos in Library though.
2015-9-30
AirMaN
I Have 9.0.2 and have no issues. I'm using an ipad Air 2, 1.4 firmware on the bird. Everything runs smooth, flight logs are fine. I've tested it in Autopilot app and DJI GO.
2015-9-30
Phuglie
BRENT1956@GMAIL Posted at 2015-10-1 01:44
Has Director disappeared too? Never really used it but cannot see it anywhere? Any clues? I can ge ...
No it's still there - just go to library and click on a video - you'll see it (in the background)
2015-10-4
ghoonk
Flight distance : 394626 ft
United Arab Emirates
DJI Go 2.3.0 has been updated to be stable/compatible with iOS9, AFAIK
2015-10-13
