ag0n
Flight distance : 700846 ft
Like you said, taking them off and putting them on will stress the threads in the plastic hub. I rarely take them off, and never for storage or transport. Most cases seem to handle the props just fine when attached. I also never use the wrench. With the proper grip, you can remove the prop with one hand, no wrench, even after they've been on a long time. Just be absolutely SURE that you are turning the correct direction. Going the wrong way when they are tight will stress the threads even more. |
