Blackbuckone
Flight distance : 126191 ft
It's never one I've put in, it's always a factory fitted screw on the props put in by DJI.
Once again despite buying a proper screwdriver, when out the other day one of the props took a battering from something in the air causing a split to one of the props and a very slight nick to the other.
First one came off no problem and replaced fine, the other one the dreaded thread immediately twisted and has lost all purchase, and it is now stuck and the prop can not be removed.
The last time this happened, I had to cut off the plastic base of the prop until it could be freed, not a nice job with such a delicate piece of kit.
Why oh why do you use these cheap nasty screws, DJI, they are rubbish as are the screwdrivers you supply.
This is not a good thing to have to do to your drone, so if anyone can offer a better solution in getting this stuck screw out I'd be most grateful.
Regards
