Antennas on the P3 Pro
996 4 2015-9-30
jaronpv
Flight distance : 723776 ft
All four legs have antennas.... So here is my question.  What does each do? anyone know? 2 for control, 2 lightbridge? or what?
2015-9-30
suhailimtiaz
Jaronpv,
My understanding is that all four of them are lightbridge antennas that connect to the OFDM module and work together to maximize your range in flight.  They are on all four corners so that you will have coverage no matter which way the aircraft is facing relative to your position.   The back right leg also has the compass wire running through it.  Hope that helps!
2015-10-6
suhailimtiaz
Jaronpv,
2015-10-6
jaronpv
suhailimtiaz Posted at 2015-10-6 10:33
Jaronpv,
My understanding is that all four of them are lightbridge antennas that connect to the OF ...
Thank you!  That does make sense.  I appreciate your input.    the antenna must be dual purpose then since you need aircraft control in addition to lightbridge?  Do you think that is correct?
2015-10-6
suhailimtiaz
jaronpv@hotmail Posted at 2015-10-7 01:15
Thank you!  That does make sense.  I appreciate your input.    the antenna must be dual purpose  ...
Sounds correct (just my opinion though).  Might be worth verifying with DJI or a local repair shop.
2015-10-6
