Cache locally when recording ?
15096 23 2015-10-7
BASS 666
sorry guys i searched the net and the forum but cant find the answer ... i read that turning of the above helps with video tranmission ?? what does it mean ? i thought it meant it didnt save video to my tablet and therefore helps with video feed ? i turned it off and i still have the videos on my tablet so i guess im wrong in what i thought ? can someone explaine it for me as i am stumped ....
thanks guys ....
2015-10-7
arives
Flight distance : 453684 ft
I have asked this question too, and no answer. The silence is deafening. What the heck is it?
2015-10-7
DJI-Tim
DJI Team
It means that by turning off chash you are freeing up your device ram and gpu
2015-10-8
BASS 666
DJI-Tim Posted at 2015-10-8 10:46
how does it free it up when it still records onto the tab ?
2015-10-8
DJI-Tim
DJI Team
BASS 666 Posted at 2015-10-8 18:25
if you turn off cash, it will only record to sd
2015-10-8
BASS 666
DJI-Tim Posted at 2015-10-8 11:27
I have it turned off and I still get the recordings on my tab ?
2015-10-8
BASS 666
69 views and still no answer ? someone is bound to know whats going on with this ....
2015-10-8
Swedrone
Flight distance : 15419022 ft
Sweden
Ask the person you heard that from. Im not sure why turning it of should help with your feed. I like to have it set to max 2gb which is a lot of 720p...in case I loose my bird I at least have something from the crash.
2015-10-11
jimcloud74
Flight distance : 1298317 ft
BASS 666 Posted at 2015-10-9 00:47
I turn cache off and have no local videos on the tablet. Not sure why you would still have videos with it off. Turn it off and click on "clear local cache". Go fly and see what happens. You shouldn't have videos. Some people have heating problems and and "laggy" video when caching. I haven't experienced that in a while even when caching. Hope this helps.
2015-10-11
BASS 666
jimcloud74@yaho Posted at 2015-10-11 15:33
I turn cache off and have no local videos on the tablet. Not sure why you would still have videos  ...
thank you mate ... I have tried everything and its still putting it onto the tablet .. iv cleared the cache turned it on and off a few times but it keeps putting it onto the tablet as well as the sd card .... it puts the pictures on as well .. its like the option for turning it off doesn't work ?
2015-10-12
jimcloud74
BASS 666 Posted at 2015-10-12 15:33
thank you mate ... I have tried everything and its still putting it onto the tablet .. iv cleared  ...
What os are you using? Apple or Android?
2015-10-12
BASS 666
jimcloud74@yaho Posted at 2015-10-12 21:34
android mate ....
2015-10-12
terrylewis
Flight distance : 3517287 ft
Just for confirmation, most settings are stored either on the P3 itself or on the RC, when you change the configuration, is your RC/P3/TAB all powered up? On my Note 4, when local cache is turned on, the lower res photos/videos are captured locally (along with an info file) on Device Storage at /DJI/dji.pilot/DJI_RECORD. When I turn off the cache locally, no files are captured. You can additionally make the cache "auto-cleaning" with the Auto Clean up Video Cache (when over 2GB). Below both of the cache settings is the Clear Video Cache button that will  delete the contents of the DJI_RECORD folder whether you are connected to the P3 or not:
2015-10-12
BASS 666
terrylewis Posted at 2015-10-13 00:36
Just for confirmation, most settings are stored either on the P3 itself or on the RC, when you cha ...
yes I have it all powered up when im trying it .... its 100% turned off and its still putting videos into my tablet .. its really odd ....
2015-10-12
greenbean
Flight distance : 84783 ft
I had asked some time ago and was told not to bother with caching. it will only cache in 720p and there really is no need to……unless I guess one might not have a sd installed
2015-10-12
BASS 666
greenbean Posted at 2015-10-13 04:53
I had asked some time ago and was told not to bother with caching. it will only cache in 720p and th ...
that's the whole point of my thread .. I don't want to cache to my tablet but it wont switch off .....
2015-10-13
nabesarawak
Malaysia
Did you try to uninstall DJI Go App and reinstall again ?
I am android also to off the cache setting and no cache video recorded in tab....
2015-10-13
BASS 666
nabesarawak Posted at 2015-10-13 14:51
I am android also to off the cache settin ...
I use the old pilot app as I don't want the new go app ... im still on 1.1.9 fw because I don't need all the new stuff ..
2015-10-13
BASS 666
heres a very bad video of what is going on .. i take a small vid then hit the play button on the RC and it shows the vid on my tab and i have cache turned off ....
2015-10-15
BASS 666
looks like I will have to live with this problem as there is no way to fix it ....
2015-10-16
silverxrider.me
I had to turn mine off with the last update due to a bad stutter in the live feed during recording, never had a problem prior to the last update. One step forward and two back.
2015-10-16
BASS 666
silverxrider.me Posted at 2015-10-16 21:13
I had to turn mine off with the last update due to a bad stutter in the live feed during recording,  ...
I want to turn mine off to see if it helps my video feed but its a no go ....
2015-10-16
silverxrider.me
BASS 666 Posted at 2015-10-16 13:28
The reason is likely the older firmware you are using which might not support that function. I am on the latest Go app and firmware and the bird flies great, but I had a bad live feed stutter, and turning off the cache function smoothed it back out.
I might mention I only had the stutter while recording video, which turned out fine, just the live feed was affected.
2015-10-16
BASS 666
silverxrider.me Posted at 2015-10-17 02:17
The reason is likely the older firmware you are using which might not support that function. I am o ...
thank you .... im staying with the old fw for now as I like the way the bird flies ....
2015-10-17
