OSMO P3 gimbal vibration/feeling
242 5 1-7 23:29
grimdina1
Romania
Hello. When moving the Osmo Pocket 3 to look in the left and right direction and the gimbal follows, if I do it fast I feel something in the gimbal, maybe like a vibration or some gears. It happens when moving the gimbal very fast, when moving slow I don't feel it. And there is no sound of this problem. Is it normal? Thanks.
1-7 23:29
DJI Wanda
Hi, there
Thanks for your question.
Could you please take a video showing the Pocket 3 issue?
You may save it through a shareable link like Google Drive and DropBox, then send the link here.
We will check it further for you. Thanks
1-7 23:36
grimdina1
Romania
DJI Wanda Posted at 1-7 23:36
Hi, there
https://imgur.com/a/FKhzRHn
Hope sending the video using Imgur is okay. Now I can barely feel it, a little bit earlier I tried again and felt it a tad bit harder. I tried calibrating
1-8 00:03
DJI Wanda
grimdina1 Posted at 1-8 00:03
Hi, there
Thanks for your information.
We suggest you update the Pocket 3 to latest firmware via DJI Mimo App and try to calibrate it.
Please keep us updated after trying, thanks
1-8 01:33
grimdina1
Romania
DJI Wanda Posted at 1-8 01:33
Hi, there
Hello, I did that and still same results. I noticed I can also feel it when moving the camera back and forth to selfie mode. As I said, it is very very subtle. Can you please check and tell me if it also happens to the Osmo P3 you have available? Just wondering if it is normal
1-8 07:05
DJI Stephen
grimdina1 Posted at 1-8 07:05
Hello grimdina1,
Thank you for sharing the video and providing details about the issue you're experiencing with your Osmo Pocket 3. You mentioned a sensation in the gimbal when moving it quickly to the left or right. We recommend trying the following settings:
Gimbal Follow Mode settings: Gimbal Follow/Default Stabilization
Gimbal follow speed settings suggestions: Sensitive follow / sensitive gimbal /Gimbal turning speed: default, fast
You may also refer to the user manual for more information:
https://dl.djicdn.com/downloads/ ... _Manual_v1.0_en.pdf
Thank you for your cooperation.
1-9 02:22
