DJI GO 2.4.0 is now available and RC Firmware 1.4.30
3110 11 2015-10-21
GQ.
I just did DJI GO 2.4.0 update on my iPad Mini 4 with the iOS 9.0.2 and did the new RC firmware 1.4.30 update as well.
RC update was done directly from the App in less than 5 min. Great and simple.
I did a quick flight and everything works perfect for me here.
2015-10-21
mariano76
Flight distance : 509196 ft
I got android and just updated RC only. Is there any release notes about this new RC firmware?
2015-10-21
GQ.
mariano76 Posted at 2015-10-21 18:03
I did not see any release notes about the RC update firmware.
2015-10-21
voyager4000
Flight distance : 192172 ft
As far I can see this is what has changed
1. Added support for Zenmuse X5 series gimbal.
2. Support bandwidth allocation feature for Lightbridge 2.
3. Bug fixes.        4. adjust Gimbal Roll on C2
2015-10-22
Simone.pasquali
Hello,
after upgrade to versione 2.4.0 the app always crush when I access the Library and try to make a movie.
Anyone same problem?
Got it on Samsung Galaxy S5.
2015-10-23
GQ.
Simone.pasquali Posted at 2015-10-23 08:39
Hello,
after upgrade to versione 2.4.0 the app always crush when I access the Library and try to ma ...
Reboot your tablet.
2015-10-23
Simone.pasquali
GQ. Posted at 2015-10-23 15:52
Reboot your tablet.
Rebooted, same problem.
I unistalled DJI GO, clear all file, downloaded DJI GO app on DJI website ad .apk
Same problem. So sad.
2015-10-23
HisRoyalDoognes
I got my brand new P3 Pro today and did all the updates to latest version mentioned above successfully.
All went well, but YouTube stream refuses to start.  I get my encoder started, but the streaming piece never starts.  The link is generated and it works on the site, but you get the "about to start" screen since the streaming actually never starts from within the DJI GO app.  I'm using a Samsung Galaxy S6 with plenty of memory.  I tried both Video on and off.  I did not take off.  Any ideas if this is a bug in the new version???? Since it's my first experience, I don't have a prior reference, but several folks indicated to me that it did work on a prior version.  Appreciate your help.....
2015-10-23
aadoat
Flight distance : 3113757 ft
The new rc firmware 1.4.30 has shorten the battery life of my inspire 1, at least 30% off. TB47 only lasts around 10-12mins, TB48 lasts 15mins max. Has anyone noticed that??
2015-10-25
GQ.
Simone.pasquali Posted at 2015-10-23 10:49
I unistalled DJI GO, clear all file, downloaded DJI GO app on DJI website ...
Call DJI service.
2015-10-25
William Burrows
Flight distance : 228698 ft
I have notice that I get a weak signal warning or I loose the signal completely more than I did before the firmware upgrade.  I have been grounded for sometime because of the strong winds in my  area.  I did get a fight in when the winds died down and notice my signal is normal flying down wind but up wind in the same direction the signal problem reappears.
Is this just a weather issue?
Thanks,
William E. Burrows Jr.
2015-10-27
GQ.
William Burrows Posted at 2015-10-27 06:18
I have notice that I get a weak signal warning or I loose the signal completely more than I did befo ...
Did you update your DJI Go and RC firmware ?
2015-10-27
