X5 - what is "higher speed signal readout"
940 2 2015-11-9
adam
DJI/Anyone,
The DJI X5 product page has the following quote:
"A higher speed signal readout suppresses the rolling shutter effect when recording, resulting in beautiful footage even when flying at high
speeds"
What is "higher speed signal readout" and how does it reduce rolling shutter when recording?
2015-11-9
Mike-the-cat
Flight distance : 22488593 ft
Singapore
An image frame is a string of data that describes pixels from the top left of the frame to the bottom right of the frame. This is unlike film where the image is simultaneously recorded across the entire frame.
Rolling shutter: mis-registration of vertical lines occurs because of the finite time that elapses between the 'read out' process. The longer it is, the more time elapses between the scene record from the top left to the bottom left. If the contents of the scene shift horizontally (e.g. rapid pan), then will get a 'rolling shutter' effect. The analogy is of motion blur at low shutter speeds.
2015-11-29
adam
Mike-the-cat Posted at 2015-11-30 08:24
An image frame is a string of data that describes pixels from the top left of the frame to the botto ...
Got it!  Thank you for the detailed response
2015-11-30
