motor wires insulation compromised
955 11 2015-11-29
draadkar
Nigeria
It seems, at closer inspection, that the vibration of the craft while flying does some damage to the electric supply wires of the motors. this can at some time cause a short against the metal frame of the motor and cause an unexplained crash. this is after 6 months and many flights. I am now adding insulation to prevent possible catastrophy.
2015-11-29
CaveDrone
Flight distance : 11549 ft
I have had issue with the same type of cheap plastic wire insulation on the machines I service.  Over time they break down and crack at the bend points exposing bare wire causing all kinds of random issues.  Not good for the Phantom for sure!   I have added heat shrink tubing  to the individual wires with good success.  You will have to unsolder the wire first though!
2015-11-29
gregg1r
CaveDrone Posted at 2015-11-29 10:52
I have had issue with the same type of cheap plastic wire insulation on the machines I service.  Ove ...
Yes, you can remove the wires from the speed controllers and slide heat shrink over the wires, or you  can use rubber splicing tape without removal..
Properly repairing does require either unsoldering the wires or cutting and splicing the repaired wires back together.
2015-11-29
draadkar
Nigeria
CaveDrone Posted at 2015-11-29 16:52
Thanks for the advice. However i made some 25mm long sleeves from another electrical wire just to assist where it is rubbing.
2015-11-29
CaveDrone
draadkar Posted at 2015-11-29 11:09
Thanks for the advice. However i made some 25mm long sleeves from another electrical wire just to  ...
I see that in your original post.  Thanks for sharing that issue "to be",     "An ounce of Prevention is worth a pound of cure" - Benjamin Franklin
2015-11-29
draadkar
Nigeria
CaveDrone Posted at 2015-11-29 18:34
I see that in your original post.  Thanks for sharing that issue "to be",     "An ounce of Preve ...
its a pity that Franklin never owned a drone
2015-11-29
aburkefl
Flight distance : 78612 ft
draadkar Posted at 2015-11-29 12:37
Lightning would have fried his drone! LOL
2015-11-29
draadkar
Nigeria
aburkefl@gmail. Posted at 2015-11-29 21:46
hahahaha but i believe his kite was ok
2015-11-29
AG0N-Gary
Flight distance : 700846 ft
I haven't disassembled mine to look at it in detail, but from your picture, I wonder if a little strain relief might also help.  That is, carefully carving away a little plastic to relieve any pressure on that point.
2015-11-29
draadkar
Nigeria
AG0N-Gary Posted at 2015-11-30 03:56
I haven't disassembled mine to look at it in detail, but from your picture, I wonder if a little str ...
You know you are right. I have considered to cut the clip that guide and holds the motor on the side of the wires because it is the culprit. I believe the older P3's did not have them. that would still leave three others to brace the motor.
2015-11-29
Kneepuck
Flight distance : 275105 ft
CaveDrone Posted at 2015-11-29 07:52
LOL, I have had the problem with expensive things. My Mercedes, and I am not the only one, has wiring harness issues with insulation cracking off and shorting. Penny pinching on what is supposed to be a quality product should be punishable, somehow.
2015-11-30
CaveDrone
Kneepuck Posted at 2015-11-30 14:50
LOL, I have had the problem with expensive things. My Mercedes, and I am not the only one, has wir ...
Really,  punishment sounds good,  LOL.   The machines I work on cost upwards of $40k.  They use cable ties that are so tight they look like a grown man bulging out in toddler clothing...
2015-11-30
