H3 3D gimbal trim
1463 4 2014-12-26
wiperdog
Hi im a new phantom 2 owner with H3 3D gimbal. Its attached and working, however it is trimmed at around 45 degrees down and the remote control wheel only moves it a few degrees up and down (and it always retiurnd to the origional low setting. Anyone know what im missing here?
thanks
2014-12-26
mephis.bell
I'm having that EXACT same problem........as soon as it finishes to stabilise, it points about 50 degrees down, and does not level off in a straight and level attitude. it just points down...............
2014-12-26
Gerard Nijenbri
Flight distance : 62241 ft
On start-up my GoPro is facing 45 degs downward as well. Not a big deal, however a horizontal starting position would be nicer in my opinion.
In order to use the whole 90 degs of travel (from 45 degs up to horizontal, and then down to straight vertical, I had to change the 'Horizontal Limit' and the 'Vertical Limit' in the Advanced > Gimbal section of the Assistant software. Both are now at value '0' (which is exactly horizontal at the right end of the tilt-dial to exactly vertical at the left end).
Gerard
2014-12-28
Gerard Nijenbri
These are my settings:
2014-12-28
adamshuntington
Happy Holidays!  It is angled downward so it doesn't capture the rotor blades in the FOV.  If you want to increase the rotating range of the the gimbal, download the apps for the P2 and the RC... if you have a Mac, you'll have to disable the app download security in the security settings.
Plug the P2 in to your computer and using the app you can increase the rotating speed and range of the gimbal.  You do not want to reestablish a new default point because of the reason presented above coupled with the fact that I don't think you can.   Play around with the app and the X1 setting.
Gerard posted a good screen shot.  I have a lot more range now after modifying these settings.
2014-12-28
