nrgwise
trying to get a better handle on the symptoms: When does this hiccup occur:
A) immediately when I start and only then
B) intermittently during recording
C) at start and then intermittently
As for the .jpg/RAW thing. What do you mean by '.jpg went wonky?' This sounds like a hardware failure/camera function failure and should be looked into. When you change settings for the camera, do you visibly see a change in the display AND on the photos/videos?
What I see in the photo posted above looks like shutter lag and would be there until the shutter cycles completely at least once in video mode, always there in photo mode. However, the difference between .jpg and RAW and how the camera handles the processing of each may be why one seems okay and the other doesn't if it is a shutter proble. An example of a 'wonky' .jpg would be nice.
In either case, it appears you have an electronics or a shutter problem in the camera from the info you provided. And/or an optical problem, but that seems less likely.
