terrylewis
Flight distance : 3517287 ft
Sikorsky Pilot,
The firmware bin file is placed on the SD card and put into the camera just so that it can be installed to the various P3 components that are driven by the firmware. After your P3 is updated, the bin is no longer needed to remain on the Card and unless you have videos or photos that you want to keep, it's perfectly safe to reformat the SD Card. There is a file transfer capability built into the GO App, but the files are usually so large that it's easier to just take the SD Card over to your computer and transfer them manually using your card reader. After you've save the photos/videos, it's easiest to just put the SD Card back into the camera and them format it using the GO App. Reformatting will erase the hidden index and thumbnails that would not otherwise be deleted. |
