me.frederikheit
Sweden
Hi guys.
Depending on where Albert is located, I´m afraid he´s correct or partly correct at least.
Im based in Denmark and to be able to obtain a commercial license, it is requested to have a "failsafe alarm" built in to your system.
This however does not apply if your not flying under a licence.
I am too looking in the this at the moment and have tested a few "find me" buzzers intended for, well you guessed it, finding your aircraft, when lost.
All the systems I tested is meant to be mounted between your rx and a servo and will go off if signal is lost.
This however, is not working on a (in my case) WKM system and I am looking for alternatives at the moment.
Since the A2 / WKM already has a built in beeper/ buzzer, it would make a lot of sense for DJI to implement this as a feature with an firmware update.
Albert, did you find a solution to this?
And does anyone else have a suggestion for a fix for this?
Safe flying
- Cheers
Frederik |
