DJI-Ken
Flight distance : 1515312 ft
It sounds like you are new to these multirotors, my suggestion is to read the manual and watch the tutorial videos and play with the simulator. All of those are located in the Academy page of the app. From the home page (when you first power everything up, RC first then aircraft) the icon on the top right (graduation hat) takes you into the Academy page where everything is.
The top left icon (paper airplane) form the home page takes you to your flight logs.
After doing a firmware update, you need to calibrate the IMU, then the compass (compass calibration outside no metal around,no phone/keys in your pocket, RC on the ground not in your hand)
Then a gimbal calibration. The IMU calibration can be done around metal but just has to be an a perfectly surface and not toughed during the 10 minute process.
Also, the gimbal calibration takes about 10 seconds until you'll see the camera move in all directions, so don't touch the aircraft until its finished.
