Seious live lag with X5 on Inspire 1
1088 11 2016-1-25
szeles.m
Flight distance : 20042933 ft
Hungary
I just got the X5 camera from DJI.
Installed it and so and boom, it comes... Check video please.
Is this normal with the X5 cam? The X3 is much more fluid! I changed it back to the X3, and it's perfect!
Firmware updated, checked with more devices, reinstalled DJI GO, and so...
Any ideas?
Thanks in advance!
2016-1-25
DJI-Ken
Flight distance : 1515312 ft
What frame rate are you using, and you also did all the calibrations right?
2016-1-25
szeles.m
Hungary
DJI-Ken Posted at 2016-1-25 18:38
Hello,
I'm using 4K 24FPS, and did the gimbal and focus calibration. That's it?
2016-1-25
Jwmulcahey
Flight distance : 396142 ft
Mine was doing this as well on my last shoot. Everything was calibrated and I was in the middle of nowhere with no electronics around so interference wasn't an issue. I'm doing another shoot today, I will update here if  come up with a solution at all.
2016-1-25
DJI-Ken
szeles.m@gmail. Posted at 2016-1-26 01:41
Hello,
If the X3 works fine in the same location that it could be the camera.
Can you try it outside and see what happens, also you can slow the video transmission quality and use custom and try a different channel.
2016-1-25
szeles.m
Hungary
Jwmulcahey Posted at 2016-1-25 18:56
Mine was doing this as well on my last shoot. Everything was calibrated and I was in the middle of n ...
Thanks a lot in advance!
2016-1-25
szeles.m
Hungary
DJI-Ken Posted at 2016-1-25 19:02
Can you try it outside and  ...
I'll also check it outside tomorrow.
I tried changing the video transmission, if I set any value, it stays the same.
2016-1-25
DJI-Ken
szeles.m@gmail. Posted at 2016-1-26 03:22
I tried changing the video transmission, if I set any value,  ...
I talked to the camera guy and he said that if nothing helps when you are outside it may be the camera.
But, I just tested the X5 and X3 and there is a tiny lag in the live video. I'm also in an area with tons of electronic interference. But is is strange that you X3 is perfect and the X5 has a tiny stutter.
If your able to, make a comparison video so the tech can see the difference
2016-1-25
Drone Cuiabá
Flight distance : 13272894 ft
DJI-Ken Posted at 2016-1-26 02:02
Ken, I have a curious information on crashes in the image.
At about two months began to freeze my image in the mini ipad 2. I tried all possible configurations and did not improve at all. Saturday I decided to open the "nose" to see if there were any loose cable or something. There was nothing loose, just looked and closed. When I tested again magically no longer had any lag.
Yesterday flew and went to 1.5km away and not frozen. I do not know what happened! Just did this and gave no lag.
2016-1-25
szeles.m
Hungary
Drone Cuiabá Posted at 2016-1-25 20:34
At about two months began to freeze m ...
If it'd make the same lag with X3 and X5 I'd check the cables and so. But it's doing for only the X5, it's so strange...
2016-1-25
szeles.m
Hungary
DJI-Ken Posted at 2016-1-25 20:31
I talked to the camera guy and he said that if nothing helps when you are outside it may be the ca ...
Okay thank you, I'll make a video in some minutes
2016-1-25
szeles.m
Hungary
Okay, I uploaded a comparison. You can see the X3 latency compared to the X5. Same enviroment, no radio devices nearby indoor. Same as outdoor!Check here:
2016-1-25
