amitregev
Flight distance : 791020 ft
Israel
Hi RichMorgan! It sounds as if one of the connections on the Flytrex adapter might be loose a bit and gets disconnected while flying, basically causing the Flytrex Live system to lose power, gets disconnected and reconnected back again, basically restarting the Live connection.
If possible, please post a few pictures showing a close-up of your adapter connections and I'll gladly see if I can identify anything or give any advice on this. If this won't help, we can arrange a new adapter shipment to you and this will hopefully help with this problem. If you prefer, feel free to email us the pictures to support[at]flytrex[dot]com and our team will review those quickly.
Another small test that you can do is power up the Phantom on the ground/table, and after the Live goes to flashing green try moving the wires on the Live adapter a bit - no need to put much pressure, just moving them slightly by putting a bit of pressure with your finger and see if the Live restarts as a result - this might give good indication if a power is lower during flight as well.
Looking forward to your follow-up. Cheers!
-Amit-
Flytrex Team - flytrex.com |
