Different firmware versions for aircraft and RC
1074 11 2016-2-13
morten.eriksen
Sweden
Hi.
I'm new in the world of Phantoms. Is it normal that the firmware versions for the RC & aircraft are different? If yes, how to know if you have the latest version?
I got 1.5.70 for the RC and 1.6.40 for the aircraft. The newest FW @DJI.com is v1.6.0040, but I'm not able to upgrade the RC to that level.
Please support a rookie
Thx,
Morten
2016-2-13
rmr3131
Hey morgen if you have a standard or 4K they update via wifi automatically, so unless you are an idiot while downloading bin file , you should be fine!
2016-2-13
rmr3131
I'm sorry morten rc updates via wifi craft via sd card
2016-2-13
morten.eriksen
Sweden
It is an adv.
2016-2-13
morten.eriksen
Sweden
OK, so different versions are OK?
2016-2-13
[RCG]Balthazar
Flight distance : 475371 ft
Norway
Yes. Also note that your batteries have firmware and needs to be updated.
2016-2-13
morten.eriksen
Denmark
[RCG]Balthazar Posted at 2016-2-13 17:47
Thx. Regarding the batteries. I assume that the battery use to upgrade the aircraft is "automatically" upgraded at the same time as the aircraft, but what about the extra battery? Any quick guide or videos?
2016-2-13
[RCG]Balthazar
Norway
Updating Multiple Batteries
Just leave the FW on your SD and change battery. Then let it do its thing. Change battery again and let it do its thin. Repeat till all batteries are updated. Delete ,bin from SD. Make AWESOME video. Share here
2016-2-13
AG0N-Gary
Flight distance : 700846 ft
Your DJI Go app should tell you if you need an upgrade.
2016-2-13
rickb33952
morten.eriksen Posted at 2016-2-13 12:09
Thx. Regarding the batteries. I assume that the battery use to upgrade the aircraft is "automatica ...
Morten,
I also have two firmware versions. The RC updated itself via WIFI and the DJI-Go application. I then encountered issues with using the downloaded firmware after copying it from a Mac computer to the Micro-SD. The Aircraft refused to update when the SD was inserted. So as a work around I switched to a PC and formatted the SD and downloaded, extracted and copied the .bin file to the Micro-SD a second time. When inserted into the aircraft the update proceeded with no problems.
After removing the Micro-SD and placing it into a USB reader adapter, I inserted the adapter into the RC and nothing occurred and eventually powered down after several minutes.
I then powered up the RC with an iPhone and started DJI-Go and then powered the Aircraft. No updates requested and all appears normal. Versions for the aircraft and the RC are as you stated:
APP version 2.6.0
Aircraft version 1.6.40
RC version 1.5.70
Should I calibrate and fly?
2016-2-20
morralser
Mexico
Hola mi drone me aparece en amarillo gimbal motor overload alguien me puede ayudar?
2016-2-20
DJI-Ken
Flight distance : 1515312 ft
rickb33952 Posted at 2016-2-21 13:12
Morten,
I also have two firmware versions. The RC updated itself via WIFI and the DJI-Go applicati ...
Everything is updated, calibrate the IMU, compass, and gimbal and go fly.
2016-2-20
