IPAD Holder Screw
668 3 2016-2-13
Artiks
Flight distance : 979964 ft
Portugal
Hey guys!
As all of you know, the tablet/phone holder is attached to the transmitter with a screw. During the unpacking/packing of the drone everytime we use it, the screw gets loose and you can't adjust the device angle accordingly to your needs so you need to tighten again to make that happen.
The problem is that the screw is made with some sort of (plastic?) and its head gets scratched we can't tighten anymore. Do you guys think if we change for a aluminum/metal screw is a problem because of the antennas/signal? They are a lot more consistent...
I don't think that a screw is a problem for the antennas since the iPad itself has a lot of components that could cause more harm
Any of you have experienced our issue? How do you proceed?
Cheers
2016-2-13
DJI-Tim
Just tightening the screw always worked for me. However with the time it's getting loose and needs to be tighten again.
Also the screw is made of metal, not plastic ,so even if you change it  it will not influence the signal
2016-2-13
Artiks
Portugal
DJI-Tim Posted at 2016-2-14 10:37
Just tightening the screw always worked for me. However with the time it's getting loose and needs t ...
Hi Tim, thanks  for the answer.
My concern is because the screw i want to use has magnet and I don't know if it can interfere with the signal.  If it doesn't... well, those are good news =)
2016-2-14
DJI-Tim
Artiks Posted at 2016-2-15 03:06
My concern is because the screw i want to use has magnet and I do ...
magnet... then you have to keep it far from the aircraft's compass, however remote must be ok
2016-2-14
