pbpubmac
Flight distance : 75873 ft
Hi:
How are you guys adjusting f stop, shutter speed, iso, peaking, zebras with an Inspire Pro? I assume that you must still do this in the DJI GO app, which I just tried to do, then switched to Autopilot for a simple Target mission 100 feet up. First thing that happened is the app did the count down, then refused to take off, showed on error on the iPad. Got a rapid green blinking from the aircraft which indicated a connection, right? Switched back to P mode and the aircraft took off..While the camera maintained focus lock, the video was out of focus and there was nothing I could no about it. Then tried to land and the auto landing gear sequence wouldn't run. Had to land manually. This is a definite gotcha as you can easily damage the Inspire's gimbal if you like to auto land. |
