mikael
Flight distance : 24199 ft
Sweden
It doesn't work. The law of physics. If you have 1 gallon of air at the surface, it compresses to 50% at 30 ft below surface cutting the lifting power to half. At 60 ft below the surface it compresses by another 50% to 25% of the original volume, cutting the lifting power by half again. So If the lifting power is 4 lbs at the surface, it will be 2 lbs at 30 ft and 1 lbs at 60 ft. Since it doesn't deploy instantly when hitting water it won't be able to lift your drone. At least not those units I'm afraid. Sorry. |
