DJI-KEN - PHANTOM 4 HEIGHT RESTRICTIONS important questino re: phant
2809 21 2016-3-1
djiphantom3xx
Hi DJI-KEN -
Can you confirm the phantom 4 can still go max 500m? I just noticed on the specs page (which wasn't available when I ordered) - that it NOW says "max 400 FEET" above take off?
Can you confirm that is just the 'default' - but I can still override it to go 500m (roughly 1500 feet?)
Thanks!
2016-3-1
djiphantom3xx
any response? ty!
2016-3-1
dacofty
Flight distance : 1061345 ft
Wonder why this question hasnt been answered, its been asked in several posts but seemed to be overlooked.  I think this is a serious question that could be a deciding factor in purchasing or not
2016-3-1
stevegreentechy
Flight distance : 558031 ft
Introducing the Phantom 4 thread post number 35. No it cant go above 400ft
2016-3-1
Username Here
Give them a chance to do some checking. The P4 is most likely new to them also.
2016-3-1
dacofty
Username Here Posted at 2016-3-1 15:10
dont you suppose they have already been briefed on this when it was in beta and final release?
2016-3-1
stevegreentechy
DJI-Ken35# 2016-03-02 03:56reply Quote: djiphantom3xx Posted at 2016-3-2 03:51 @DJI-KEN - can you please confirm it can still do 500m (1500 feet)? On the specs page - it seems to  ...  No you cannot, the max height is 400ft from take off point.
2016-3-1
wheeliesteve
The Phantom 3 currently is supposed to be able to go 1640 feet  in altitude from take off point. How long before they push out a firmware update to restrict it to 400 feet like the Phantom 4?
2016-3-1
Highlander Brow
DJI-Ken Posted at 2016-3-1 20:50 The max altitude is limited to 400ft from take off point.
2016-3-1
SHamers
Flight distance : 1001020 ft
Yes and why 400ft - this new bird can see obstacals so if the 747 is in front of him.....he just avoid the kiss!
Sorry bad joke!
400ft is fine for me but i am living in flat Nederlands (-8 under see level)
TIP to DJI communicate if you change the P3 firmware with the new 400ft restriction.
2016-3-1
Bhujang
Flight distance : 534587 ft
wheeliesteve Posted at 2016-3-1 20:46
The Phantom 3 currently is supposed to be able to go 1640 feet  in altitude from take off point. How ...
Just don't do the fw update ;) simples
2016-3-1
bikkelrealg2
Flight distance : 481175 ft
From DJI site, so its the same as P3
BEGINNER MODE
The Phantom 4’s beginner mode limits Beginner flyers to 100ft (30m) up and away. It also prevents camera tilt controls to allow beginner pilots to familiarize themselves with flying before adding more distance and camera control. When beginner mode is switched off, the Phantom 4 will default to a maximum flight altitude of 390ft (120m) above the takeoff point. This can be adjusted to a maximum of 1640ft (500m). You can also set your own maximum distance.
2016-3-1
Elmer Fudd
wheeliesteve Posted at 2016-3-1 15:46
This is why i stayed at 1.4. The restrictions will come no doubt.
2016-3-1
DJI-Ken
Flight distance : 1515312 ft
I'm sorry I was given different information earlier,
The max altitude is indeed 500m from take off point.
2016-3-1
dacofty
I would hold off on any firmware updates until we see what type height people are getting, if 400 ft then DJI will roll out a firmware to hit the P3s,  lets hope the confusion is worked out soon.
2016-3-1
Username Here
dacofty Posted at 2016-3-1 15:36
I'm betting not all employees were privy to the specifications until release time.
2016-3-1
dacofty
Username Here Posted at 2016-3-1 19:24
who knows, but it seems if your gonna be in CS you would have all that info.  But then again this is DJI and you know how there CS is
2016-3-1
Tom Rocket
I spend a lot of time in Utah. There are lots of deep canyons. If I am on on the edge of a canyon and it is 600'
deep, what will happen when I want to fly my drone over the edge and  down into the canyon from the upper edge. Can I fly it to the bottom and  then back up to land on the top. A second question, if I am in the  bottom of a canyon and it is 600' to the top, can I only fly to 400'  from the bottom of the canyon?
I may have already posted this. I don't completely understand how this forum works. If I messed up, I apologize.
Tom
2016-3-2
mike.wildlight
Flight distance : 5623 ft
Tom Rocket Posted at 2016-3-3 13:06
I spend a lot of time in Utah. There are lots of deep canyons. If I am on on the edge of a canyon a ...
Yep that would mean most of your flight will be at negative altitude relative to your take-off point and there's no negative limitations
2016-3-3
chrgnu
Allegedly...With the P3 you can go above 500m by holding down the RTH button. I haven't tried it, saw it on a YouTube video
2016-3-3
Tom Rocket
mike.wildlight Posted at 2016-3-3 21:49
Yep that would mean most of your flight will be at negative altitude relative to your take-off poi ...
Thanks for your response!
2016-3-3
mike.wildlight
Tom Rocket Posted at 2016-3-4 10:15
Noting Tom that if you take off from the bottom that max you'll be able to climb is 500m
2016-3-3
