sidtx
Flight distance : 266729 ft
I bought a new battery this weekend.
I didn't know what would happen when I first used a new battery, so I decided to find out at home, before I went flying.
I pulled the props off the aircraft, inserted the new battery, and started everything up as normal.
The DJI GO app immediately said that I needed a firmware update. Interestingly, it didn't specify if this was an aircraft update or a battery update. I proceeded to allow it to update. Seemed to take about 10 minutes.
After the update, I shut everything down. Then restarted. It said it was ready to fly.
Then, just because I'm paranoid about things, I shut everything down, and inserted/restarted with the old/original battery. Everything started up with no problems.
Took her flying later that day. Everything worked without any issues. Both batteries and the aircraft worked/operated as normal.
Sid
