blades still show up in P
1029 12 2016-3-4
lukx
Poland
I though DJI fixed blades showing in video in P4 but it's still there 4.55 time :
2016-3-4
aaron.ferguson
Flight distance : 1641752 ft
They've improved it but if you fly "aggressively" (that section is in Speed mode) with the camera pointed up you're going to get the props in the shot. It's just an inherent limitation of the Phantom design. In Position mode and with the camera now a wee bit further forward it'll happen less often.
2016-3-4
Sebb
Flight distance : 498199 ft
i think that example shows Sport mode, so not surprising.
BUT: you can also clearly see them during the VERGE review at 3:10 and 3:50, and that seems to be Regular mode. could be wrong..
it s such a major flaw... i flew P2+hero4 in Iceland last September (very windy = drone always in steep angle) and about 1/3 of footage 100% unusable. I upgraded 3D printed H3-3D mount that lowers and puts cam further forward, but that barely helped.
was really hoping they would improve/eliminate it, but i guess in a craft this small hard to do. quite disappointing...
2016-3-4
aaron.ferguson
Yes but again the Phantom is flying low with a low camera angle... We're up against Euclidean geometry here!
2016-3-4
Sebb
well, how about they lower the camera and bring it forward? Or curve the arms slightly upwards?
currently it sits pretty centered and a good 2-3" off the ground. seems like there is alot of slack for that...
2016-3-4
Sebb
or how about a flight mode that doesnt allow drone to tilt into an angle that moves props into frame? sure, it would handle like a tractor and not be able to fight much wind, but it would keep you from breaking your footage if conditions are calm.
2016-3-4
lukx
Poland
I don't think speed mode have anything to do with it. In video I'm sure it heaven't reached it's top speed and they showed. Form images on dji website I understood that props are higher and also it looks liek they are a bit at the angle (like more tilted back) so I though it will be big fix. Also DJI is marketing it as action drone to film action sports. So it will have to move fast and with props showing all over in frame it will be a pity.
2016-3-4
labroides
Flight distance : 9991457 ft
lukx Posted at 2016-3-4 23:40
I don't think speed mode have anything to do with it. In video I'm sure it heaven't reached it's top ...
In Sport Mode it tilts 45˚ and you're surprised that the props can get in frame!!
It's pretty simple ... Tilt the camera down and the props aren't in the frame.
But if you're flying at 45˚ tilt you have to tilt the camera further down.
2016-3-4
aaron.ferguson
Sebb Posted at 2016-3-4 12:26
curr ...
Limited room for manouvre there - that's why the Inspire was born! The camera has been brought forward a bit which helps.
2016-3-4
aaron.ferguson
Sebb Posted at 2016-3-4 12:32
or how about a flight mode that doesnt allow drone to tilt into an angle that moves props into frame ...
That's P (Position) mode (maxes out at 10m/s - i.e. limits the tilt).
2016-3-4
thegoodtouch
Flight distance : 137283 ft
Shoot at 4K and crop down to 1080p to remove the props.
2016-3-4
Sebb
aaron.ferguson@ Posted at 2016-3-4 16:36
The Verge flew in P and they still showed
2016-3-5
nigelw
Flight distance : 518084 ft
aaron.ferguson@ Posted at 2016-3-4 15:36
It'll still tilt more flying against the wind.
2016-3-5
