phantom 4 compass error?
2636 7 2016-3-7
Jamk190
Wonder how the phantom 4 would cope with compass error mid flight with obstacle avoidance enabled, would this still work better with it being duel compass.
2016-3-7
Geebax
Having a dual compass means it can compare the reading of one against the other to verify the results. Hopefully this would mean more stable operation. Obstacle avoidance would not be dependant on the compass I would not imagine, it is a visual system working with a pair of stereoscopic cameras.
2016-3-7
DJI-Ken
Flight distance : 1515312 ft
If you ever did get a compass error, then the other one would take over.
But usually you get a compass error on the ground, if in the air than you didn't calibrate the compass correctly or your flying in an area with high metal interference.
2016-3-7
musbah
United Arab Emirates
I bought Phantom 4 recently and I am having a problem with compass calibration. I did calibration many times and the error message still there and when I checked the status of the IMU and the compass it shows that compass 1 is disconnected. Any one can help me to resolve this issue.
2016-6-24
Geebax
musbah Posted at 2016-6-25 09:08
I bought Phantom 4 recently and I am having a problem with compass calibration. I did calibration ma ...
If it says that, then it needs to go back to DJI to be repaired. I doubt there is anything you can do to fix that sort of problem.
2016-6-24
Cessna172
Hmmm..How does the processor decide which compass is giving the accurate data?
Seems that would require a TON more processing power than previous Phantoms.    That or there would be a lot of processing bottlenecks?
2016-6-24
user5b6373d773
Indonesia
I also experienced a compass error , please deign to give advice
http://forum.dji.com/thread-56846-1-1.html
2016-6-30
user5b6373d773
Indonesia
2016-6-30
