car charger for Phantom 4
2443 16 2016-3-18
fiord
Flight distance : 1273881 ft
Russia
Is it possible to use car charger from Phantom 3 for Phantom 4?
2016-3-18
Kirtus
The chargers are not compatible.
What I do is use a power inverter in the car that way I can plug anything in (well most anything, not a microwave).
2016-3-18
jneely
Flight distance : 629800 ft
Kirtus Posted at 2016-3-18 18:11
What I do is use a power inverter in the car that way I can plug  ...
something like this?
http://www.overtons.com/modperl/ ... ey8sCFQqoaQoddkEIsg
2016-3-18
Geebax
Kirtus Posted at 2016-3-19 10:11
Why are they not compatible? Both batteries are the same voltage, only the P4 is slightly higher capacity.
2016-3-18
Kirtus
Geebax Posted at 2016-3-19 11:16
Why are they not compatible? Both batteries are the same voltage, only the P4 is slightly higher c ...
From what I have read online and one of the videos I have seen the connectors are not compatible. So it won't plug in.
2016-3-18
Kirtus
jneely@xactly.n Posted at 2016-3-19 10:49
http://www.overtons.com/modperl/product/details.cgi?pdesc=RoadPro-200-Watt-C ...
Yes, that is correct.
2016-3-18
4StateFlyer
Kirtus Posted at 2016-3-18 22:22
From what I have read online and one of the videos I have seen the connectors are not compatible.  ...
Correct the P3 and P4 connector are very different.   So even if they are the same spec the connector would stop it.
2016-3-18
DJI-Ken
Flight distance : 1515312 ft
Correct as others have said. The connector is totally different and not like any previous Phantom.
2016-3-18
Geebax
DJI-Ken Posted at 2016-3-19 15:15
OK then, so it will take a week or so before the Chinese Car Charger people source a new connector.
2016-3-18
Andy Fiord
Russia
Thanks guys!
2016-3-25
dirter
Flight distance : 3633799 ft
I wondered about using an inverter since the waves are not sine. I decided to try it anyway but once the battery indicated it was fully charged (lights out) I tried it and it was only actually at around 60%. Seems they do play together, just not very well.
2016-3-25
mattd
dirter@frontier Posted at 2016-3-25 19:26
I wondered about using an inverter since the waves are not sine. I decided to try it anyway but once ...
I can't see how the difference between pure or square wave would make a difference to how its charged?
Are you sure perhaps the cable didn't become unplugged or your car auto switched off power to the accessories?
2016-3-26
mcritchley
Flight distance : 359278 ft
mattd Posted at 2016-3-26 11:58
I can't see how the difference between pure or square wave would make a difference to how its char ...
An inverter works ok for me in the car with P4 batteries
2016-3-26
dirter
mattd Posted at 2016-3-26 19:58
No, I'm not sure. I only tried it once and didn't want to give it another shot until I heard from some folks that are smarter than me
A car charger is a little different in that it only involves regulating an already constant flow of electrons. I only ask because I have had issues in the past running my laptop from inverters and just want to make sure here before attempting to ruin a $160 DJI battery.
2016-3-26
frank
Flight distance : 36683 ft
Norway
I got myself a 600w inverter for the same use but I didn't try it out yet. I can't see how it would not work tho. Isn't the supply for the phantom charger only a switchmode PSU that takes a very wide range of input voltage?
2016-3-26
Apmadoc
Flight distance : 3303570 ft
One additional thing when looking at an inverter.  There are several types - square wave, modified sine wave, and pure sine wave.     Pure sine wave is what you have at home, pure sine wave inverters are also more expensive than the other types.
I do know that certain electronic devices will not work at all with square wave and others are affected by modified sine wave.   I have zero idea if / how the Phantom chargers would be affected by square or modified sine wave.  Just to be safe, I stick with pure sine wave inverters
2016-3-26
crschol7
Got to any Walmart or Home Depot/Lowes... get a 400 watt inverter... appx $40... works great
2016-3-28
