Flying on mountain peaks with huge vertical drops
927 6 2016-3-19
Igor Bujanovic
Flight distance : 17333 ft
I'm planning to visit some mountains this summer (in Europe) and came to one "problem" regarding the maximum height of 500 m imposed by DJI.
Scenario : I'm standing on the mountain ridge, and there is a vertical drop of more than 500 m over which I would like to fly. The problem is - once the aircraft is over the drop, the distance to the ground is going to be > 500 m.
If I'll fly around, loose some alititude to film the rocks etc, will I be able to bring back the aircraft because the height over the ground to which the aircraft will have to fly is > 500 m ?
2016-3-19
kvamens
Norway
it calculate the altitude from where you start
2016-3-19
Igor Bujanovic
kvamens Posted at 2016-3-19 11:47
Thanks for the update, but did you try this? Playing with the Litchy  Mission Hub - it is obvious this does not work, at least in the simulation.
If I fly off the peak and add 500 m (max altitude over the ground), the aircraft is still -76 m compared to starting position ?!
"Ground Elevation: 2052m (576m below first waypoint)"
2016-3-19
kvamens
Norway
Igor Bujanovic Posted at 2016-3-19 12:00
Thanks for the update, but did you try this? Playing with the Litchy  Mission Hub - it is obvious t ...
have tried it yes, flying from a 650 m high mountain and was +120 m above, then was flying Down to -150 and up again.  But, it was on a earlier firmware so i don't know for sure on lately FW, but i quess it the same
2016-3-19
kvamens
Norway
kvamens Posted at 2016-3-19 12:09
have tried it yes, flying from a 650 m high mountain and was +120 m above, then was flying Down to ...
btw, i used DJI Og, and was manually flying (GPS mode)
2016-3-19
Igor Bujanovic
It is not a problem to fly on a mountain no matter how high it is until the surrounding terrain is not much lower.
What I ask is when you go over the edge of a vertical drop which is > 500 m...
2016-3-19
GB44
Flight distance : 343848 ft
Igor Bujanovic Posted at 2016-3-19 11:16
It is not a problem to fly on a mountain no matter how high it is until the surrounding terrain is ...
Is doesn't matter if you go over a cliff.  Its the height from take-off.  So if you fly over the edge of a cliff and drop down <50m then for example you hit the RTH it  will rise to the height set and will rise to that height before coming home.  So if RTH is set at 30m and you fly over a cliff and down 20m it will rise 40m up to the 20m height set at take- off.
2016-3-19
