New Inspire 1 Firmware problem: Craft v1.7.0.90 RC 1.5.80
3793 16 2016-3-21
jedward
There are a couple of threads about  v1.7.0.90 , but my problem is different.
1. I successfully upgraded my Remote Controller(s) to 1.5.80 by downloading and upgrading using the DJI GO app. Overall status is "Normal"
2. I successfully upgraded my Inspire 1 using the Inspire 1 Firmware v1.7.0.90 dated 2016-03-17 on the http://www.dji.com/product/inspire-1/info#downloads page.
3. I changed battery and repeated the upgrade procedure in case there was a battery firmware upgrade - there wasn't, and on the second upgrade the .txt file said the firmware on the card was older or the same as that on the craft.
4. I reboot everything, go into the status dialog, and under "Overall Status" I get a new message "Firmware Requires Upgrade!" > "!Aircraft requires upgrade".
5. I go to "... | About" and get the following:  App 2.6.0 | Aircraft 1.600.40 | RC 1.5.80 | Camera 1.7.00.90
Everything appears to be working (I can see the through camera in DJI GO, I can start the propellors), but I have this annoying message (which appears to be incorrect).
Given the other problems people have posted about  v1.7.0.90 , is this upgrade dodgy? or am I safe to fly?
2016-3-21
DJI-Tim
did you try to use it with DJI GO 2.7?
2016-3-21
Mike-the-cat
Flight distance : 22488593 ft
New Zealand
Tim, I had this problem intermittently this morning and I'm using app 2.7.1
2016-3-21
orlandoexcavati
Flight distance : 34606 ft
I don't know I have the same problem
2016-3-22
orlandoexcavati
Tip: The post by the administrator or moderators shield
2016-3-22
DJI-Ken
Flight distance : 1515312 ft
Your app is not on the latest update but your aircraft is on 1.7.
Since 1.7 was only a camera update, the camera will say 1.7 but the aircraft will still say 1.6
2016-3-22
mmassar64
Flight distance : 176335 ft
There is alot of this so It is a problem maybe with app or whatever but there is to many people reporting this.
2016-3-22
adrian
Flight distance : 1751102 ft
I had this, all the firmware numbers are correct, but in aircraft status it says 'firmware update required'  - Answer - Delete the app and re-install. Clears the message and everything works as it should.
2016-3-22
mikegrook
Flight distance : 1806125 ft
adrian@vancols. Posted at 2016-3-22 14:09
I had this, all the firmware numbers are correct, but in aircraft status it says 'firmware update re ...
Just as Adrian stated. Delete the App and reinstall and problem was gone.
Thanks for the advice!
2016-3-22
DJI-Ken
adrian@vancols. Posted at 2016-3-23 02:09
It was a server issue and it has been resolved.
2016-3-22
RichJ53
Flight distance : 1837356 ft
DJI-Ken Posted at 2016-3-22 12:30
Hi Ken
Did the server update so the new firmware reads correctly in the App now? Some have reported a lower firmware number with a + sign. I have this on my OSMO after updating it to the latest FW version.
Thanks as always for your help
Rich
2016-3-22
DJI-Ken
RichJ53 Posted at 2016-3-23 03:53
Hi Ken
Did the server update so the new firmware reads correctly in the App now? Some have report ...
For the Inspire, the 1.7 is the latest firmware update but since there was no aircraft update the aircraft will still say 1.6. The + sign just means everything to the server is not updated yet.
So whenever you see a + sign, it means you are updated and when the app connects to the DJI servers next time it will go away. If the + still hangs on, it will eventually go away.
2016-3-22
RichJ53
DJI-Ken Posted at 2016-3-22 13:04
For the Inspire, the 1.7 is the latest firmware update but since there was no aircraft update the  ...
So far what you said is true for the aircraft they have updated correctly. My OSMO has been connected to the server via the GoApp and still the firmware has not changed from the 1.0.1.19+. It also lists the other stuff App, WiFi, Gimbal, AircraftEncoder, Camera, AirOFDM
Do you have any notes on this?
Rich
2016-3-23
DJI-Ken
RichJ53 Posted at 2016-3-24 04:39
So far what you said is true for the aircraft they have updated correctly. My OSMO has been connec ...
No I don't, can you delete the app and reinstall. Then run the update again if it says update required.
2016-3-23
SkySurvey
DJI-Ken Posted at 2016-3-24 06:42
No I don't, can you delete the app and reinstall. Then run the update again if it says update requ ...
Upgraded to 2.7
Now have no camera view
and RC Version is 'Unkown" Now it says RC 1.5.70
No mention of Camera version?
Still no camera view?
Any advice
2016-3-23
DJI-Ken
SkySurvey Posted at 2016-3-24 06:17
Upgraded to 2.7
Latest RC update is 1.5.8.
What does the aircraft version say?
If it doesn't tell you then you possibly came unlinked from the aircraft. In the app there's a tutorial video on how to relink.
2016-3-23
jonodubs
New Zealand
i had an issue with the inspire not restarting after the update. it just sat there D-DD beeping until I had to manually turn it off and on... seems fine so far.
2016-3-23
