Geebax
The use of GPUs is problematic, some programs make use of them, some don't, they they will argue over which GPU architecture is compatible or not. The most important factor I find are a fast processor and SSD drives.
I have a ASUS Pro monitor, it does a good job of displaying the material, but in truth I don't care much about 4K anyway. I can't use 4K directly, there is no real release format for it, so I simply post-produce my footage as far as I can go in 4K then downscale it to 1080p for final finishing.
If you want an all-in-one solution, probably the best route is to buy a Mac Pro, they might be expensive, but they are designed from the ground up to handle 4K, and they do it well.
