Once we update to a new firmware version, is it advisable to erase the .bin and .txt files from the SD card or not?
I read somewhere that it's better to leave the files there, and in another article I read that we should erase them, otherwise they may cause problems.
Hi! You should delete them or otherwise every time that you turn on the aircraft it will check the firmware version, you will just loose time for the aircraft initialisation.
Nicola90s Posted at 2016-4-1 21:35
Hi! You should delete them or otherwise every time that you turn on the aircraft it will check the f ...
What about the "intelligent" batteries? If I buy a new battery (That might well be a new "old" battery) wouldn't it have to be updated, or will the firmware in the Phantom take care of that?
Raven , You are better to have a Blank SD card for the 99.999 % of the time you are flying. If you get a new battery simply load the Latest FW version to the SD card and update the battery, then re format and have it ready for recording.
Hi I got a question, I have a phantom 3 advanced I'm new to this. Is the firmware update the same as the professional? Also does the remote need to be updated as well? Please let me know. Thanks in advance.
pcerasuo Posted at 2016-4-3 11:33
Hi I got a question, I have a phantom 3 advanced I'm new to this. Is the firmware update the same a ...
Yes , the updating is the same for the Phantom Advanced and Pro. They have their own individual updates that are specific for each model, even though numbers are the same. yes the RC needs updating also. Please open my tips page for tips on this.
If someone can please tell me what version is supposed to be installed on the controller? Got 1.7 on P3 tried to update controller just staged with red light then started beeping. Dji app shows my controller with a 1.5 version. I'm I good to go. Thanks again.
