New P4 throwing a vision system error
12631 27 2016-4-6
info
Flight distance : 406604 ft
Brand new P4 throwing a hardware error right of the box. Forward left vison sensor error (4). Harware malfunction. Contact DJI support to arrange for repairs. Pics attached. Firmware is up to date. What do you guys think? Should I return the unit to dealer?
2016-4-6
ricardoghion
Flight distance : 1042037 ft
Brazil
Yes!!! Devolve
2016-4-6
DJI-Paladin
Flight distance : 2408 ft
Hello, you can try to calibrate the vision system via the latest DJI Assistant 2 in PC. Here is the tutorial:
https://www.djivideos.com/video_ ... d-afa8-3d4082064a81
If it could not work, I'd suggest you to contact our NA office as below:
Email: support.us@dji.com
Phone: +1 (818) 235 0789
Mon-Fri 9:00 am - 5:00 pm (PST)
2016-4-6
info
DJI-Paladin Posted at 2016-4-7 09:37
Hello, you can try to calibrate the vision system via the latest DJI Assistant 2 in PC. Here is the  ...
The error went away after rebooting. It could be just a software glitch or something more serious. As per your suggestion I will re-calibrate the vision system and further test.
2016-4-7
RobW
Flight distance : 12283 ft
I had the same situation, 3rd mission, "Vision system error" rebooted and it went away.... hmmmm?
2016-4-12
jwt873
Flight distance : 6754350 ft
This happened to me once as well.   It went away after restarting the drone.  It's never happened again.
2016-4-12
leonel_hs
Honduras
I have the same issue right now .... and I have another issue with the battery that doesn't work anymore. what should I do .... return the whole drone or just the battery ( I already noticed to DJI support) because they told to send only the battery.
2016-6-12
Jan Jensen
Denmark
leonel_hs@hotma Posted at 2016-6-12 20:07
I have the same issue right now .... and I have another issue with the battery that doesn't work an ...
3 days ago right after I had updated my p4. and would try the first test flight. that made my the same 2 times. after I had finished re-booting the last time it did not do more .. but I'm as excited about it coming back ..
it had never been there before this update and my p4 is only 1 month old.
2016-6-12
Jan Jensen
Denmark
vision system error happened again today .. rebooted ph4 and it was away .. after having flown a little and changing the battery ... I did at one time a landing to get updated home point .. then came the vision system error again .. this time I restarted just DJI . Go app. and it seemed everything again ... weird :-/
2016-6-30
DJI-Ken
Flight distance : 1515312 ft
Jan Jensen Posted at 2016-7-1 04:51
vision system error happened again today .. genstartedeph4 and it was away .. after having flown a l ...
That may happen and if power cycling doesn't clear it then do the sensor calibration.
if it still does it often then feel free to send it in to be looked at.
2016-6-30
Heebus
I too had this show up twice, I did a calibration threw dji assistant 2 n seemed to fix this problem, or so 1 battery about half spent testing seems... I also got a battery error, just as I was finished testing, it popped up so quick tho I am not exactly sure how it was worded, as I was shutting down as I had already heard the low battery warning and had landed to shut down.... charging the battery now, will try tomorrow or later to see whats up as the winds have picked up a lot, and my P4 was fighting the wind hard to stay stable
2016-6-30
Jan Jensen
Denmark
DJI-Ken Posted at 2016-6-30 23:42
if it still  ...
Today I had to fly over an area of about 3400 square meters and had to take some pictures to some archaeologists
and there were no problems at all after about 40 min trip :-)
2016-7-1
DJI-Ken
Jan Jensen Posted at 2016-7-1 12:54
Today I had to fly over an area of about 3400 square meters and had to take some pictures to some  ...
Perfect, that is great to hear.
2016-7-1
gm.stian
Flight distance : 772989 ft
Norway
Jan Jensen Posted at 2016-7-1 21:54
Also had this vision error. Rebooted both P4 and DjiGo a couple of times, and everything OK for now. Never had this problem before I updated to newest firmware. Also had an battery error along with a vision system error. That vision system calibration in Dji assistant 2 needs some work. It acts a bit strange. On my desk top computer I get an error while uploading calibration to the P4, but on a lap top, I get OK... Maby both latest firmware and dji assistant 2 needs a little more work?...
Best regards Stian
2016-7-16
scottcopeland80
Flight distance : 464721 ft
I'm having the vision warnings and I'm seeing lines of red green yellow I can fly but scared to anyone else seeing colored lines
2016-7-31
Heebus
Have you calibrated your vision sensor threw the dji assistant?
2016-7-31
thorsten.yachtc
Flight distance : 287884 ft
China
Just had the same on my P4. Should do some recordings. Could not start. 4x rebooting die not solved the problem. I cancels the job. Back at home it was working again.
Its the new FW.. it has a bug
2016-7-31
Heebus
I got this error twice, before in the same day, restarting cleared it... I eventually wiped firmware, reinstalled it, then did factory reset, and then calibrated IMU and sensors, never had the problem since then... that was 2 firmware upgrades ago...
2016-7-31
Philj6970
Flight distance : 840663 ft
I am seeing the "vision system error" all the time on Autopilot app, but not on DJI Go.
I didn't have the error on Autopilot until the latest DJI Go update.
2016-7-31
Heebus
Jan Jensen Posted at 2016-7-1 15:54
40 minute trip?... flying?... gotta battery mod?
2016-7-31
thorsten.yachtc
China
Hello Heebeus.
It can be that you like on your own to to reinstalling twice a day. But for me it is some pain. Because it cost my time. This is like Microsoft did with clienta in worse time. Reboot and reinstall and reboot.
I drove today 100 km to do some recordings. And I couldn't do it. Yous because the Firmware is faulty.
So another 100km back.
I wish that DJI is taking a bit more respect to the clients how pay them.
They have to serve me. Not different way. It's not soo hard to do better firmware.
Same to the cracks in the battery's. .Where is a official word or statement to call them back?
Every single client has to do all the time consuming progesterone to get what he paid for.
It is once to shout out "we are the best", but then you have to show it.
2016-7-31
thorsten.yachtc
China
I had with the message "visor system error"
No transmission of the camara.how to calibrate?
2016-7-31
DJI-Jamie
Flight distance : 112405 ft
scottcopeland80 Posted at 2016-8-1 08:33
I'm having the vision warnings and I'm seeing lines of red green yellow I can fly but scared to anyo ...
Are you sure the lines aren't from the obstacle avoidance indicators? Could you provide a screenshot? Have you tried calibrating the sensors via the Assistant 2 Software? What firmware are you currently on?
2016-7-31
scottcopeland80
Yes I hade to send it back
2016-8-2
patrick2274
Indonesia
How many times must I calibrate the Vision System via DJI 2 Assistant? Because my new Phantom 4 also gives out the same message: Vision System Error.
Or must I use ND4 Filter to decrease the level of UV from the sunlight?
2016-9-12
peter
Flight distance : 545377 ft
I had this one in the first few days of ownership. A reboot cleared it.
2016-9-12
Ben-benji
Flight distance : 661450 ft
Excuse me, I would like to know why this message appears on my radio when I activate the rth? descending. exited visual avoidance system, is this normal?
2017-1-20
fans47741b73
Flight distance : 19557 ft
Philippines
I got the same issue, when i first turn on then mavic i had no issue or errors. When
i restart the mavic i got this vision error "Forward Right Vision Sensor Error (a00008)".
I've done this test using different firmware (.0400, .0550, .0600, .0700),  no luck same error.
2017-5-18
