Geebax
The whole spec of suggesting a Class 10 card is misleading because the card manufacturers lie about their ratings. The writing speed of the card is vitally important, the read speed is of no consequence. There are many cards that will do the job, but I only buy Sandisk Extreme or Extreme Pro cards, as they are able to reach the speeds required.
Another point to consider though, is whether you stopped recording at the end of the flight before shutting down the aircraft. This would also cause the issue you are talking about. If you do this, the clip is not finalised on the card and will not appear. You can fix it by putting the card back in the camera and then switching on the aircraft for 30 seconds or so. But it will only recover the last file, if you shoot two or more, they will be lost, only the last written file is fixed.
