Osmo switches off while in Sleep mode
1782 5 2016-4-28
christian.eiche
Flight distance : 26608 ft
My Osmo switches off completly after about 30min. in sleep mode. battery is fully charged, Wifi on the Phone always on, Go App running. How can i keep it as long in standby as the battery lasts?
2016-4-28
nigelbrinkmann
Flight distance : 586391 ft
Mine is the same,I don't think you can change the sleep mode time before it turns itself off, can be a pain in the butt!
2016-4-29
christian.eiche
yes it´s a pain. The DJI Hotline told me it should be around 90min. sleep mode before it switches off and if that is not so with mine i have to send it in. I cannot image that  this is a mailfunction but more an issue with the firmware.
2016-4-30
DJI-Adela
The duration of a fully charged battery depends on how you use the Osmo.
With the latest Osmo firmware, you can get a longer lasting time of the battery. Without the WiFi connection, it'll be more energy-efficient.
2016-5-2
beatm01
Flight distance : 132848 ft
I've just installed the latest Firmware  (1.6.1.0) and the problem still exists. After about 30 minutes the Osmo+ still shuts down whilst in sleep mode!  It's taken me months to post this complaint, hoping DJI would act on it, but maybe not enough folks are reporting it??
2017-10-18
beatm01 Posted at 2017-10-18 01:32
When you wake up the device? Does the battery run out of power?
2017-10-18
