Rob W
Flight distance : 96152 ft
Sweden
The SSD partition containing the video have a special filesystem, only readable by Cinelight, at least as of now. It do takes time to transfer the data as the filesizes are larger (uncompressed video). Perhaps they can trim the speed on the filesystem a bit, but I would not hold my breath. It is also depending on what disks you are copying the data to. If these disks are slow, they are the bottleneck in the transfer.
There are some proxy media on the SD card, though. So you could perhaps work with those files, just as proxys, to test cuts, music etc. while you wait on the RAW files. When the RAW files are done, you could import them for real in your editing software and transfer what you did with the proxy files to the RAW files. If I'm in a hurry, that is what I would do. |
