Trouble getting Osmo to start
879 5 2016-5-7
Alastair
Flight distance : 96631 ft
Wondering if anyone has had this happen.  Since the last update, when I turn it on, the gimbal does not respond.  There is a green light on the left side and a red light on the right.  After numerous times of turning it on and off it eventually starts and performs normally for the rest of the shoot.  Then the next time I use it, the same thing happens again.  Checked the gimbal contacts and reseated it but the problem persists.  Anyone else experiencing this?
2016-5-7
nigelbrinkmann
Flight distance : 586391 ft
Hi, green light on the left (camera status indicator) normally means Firmware upgrade successful, red light on the right (system status indicator) indicates a non dji battery detected, try resetting the osmo.
2016-5-7
Alastair
nigelbrinkmann Posted at 2016-5-8 00:45
Hi, green light on the left (camera status indicator) normally means Firmware upgrade successful, re ...
Thanks, I'll give it a try.
2016-5-8
DJI-Adela
China
Hello!
After the upgrade, did you remember to remove the .bin file? Otherwise, it may try to upgrade the firmware repeatedly when you turn it on.
2016-5-8
Alastair
DJI-Adela Posted at 2016-5-8 23:43
Hello!
After the upgrade, did you remember to remove the .bin file? Otherwise, it may try to upgrade ...
I'm pretty sure I reformatted after recording the text file.  Right now it seems to be working normally.  I'll keep you posted.  Thank you.
2016-5-9
DJI-Adela
Alastair Posted at 2016-5-9 20:57
I'm pretty sure I reformatted after recording the text file.  Right now it seems to be working nor ...
OK.
If there's any other problem, please let me know.
Thanks for your support!
2016-5-9
