PWM signal value on DJI A2 controller
1884 0 2016-5-11
Kuminatano
Flight distance : 154249 ft
Argentina
Hi Everybody.!!!
Im working on several projects with my A2 controller and differents stuffs...
I'd seen that the A2 F1-F4 outputs are PWM and controls differents things, f.e. the gear (servos for landing gear)....  Well, The problem is that those (NON LABELED SERVOS) I think them are NON STANDART PWM servos. What I mean: Futaba and other servos have an standar PWM Values for the Pulsed signal (Digital signal), that works from 0V to +5V for the amplitude.
DJI A2 PWM outputs has a  0~+3.3V for the digital signal pulse (V-SEN) and 3A@5V voltage works. I can guees that the servos mounted on S900 or S1000 are non-standar servos and works with 3.3v for the digital signal.
When I want to use a common futaba servos or a relay module like arduino or pic elecronics cards to add other functions to my drone, I found an incompatible way to connect and control them...
Anyone have any idea? Any solution?
I was searching at ebay and web, that exits signal converter from 3.3v to 5v bidirectional, had anyone used it?
I will try to acquire this converter and try to connect it at the F1 or another F output from my A2 and use a standart FUTABA servo or standar 5V module relay....
If anyone is experiment with this stuff please contact me!!
Thanks a lot!
regards,
Alex
2016-5-11
