Maximum Distance from Master RC to Slave RC
1785 2 2016-5-18
str1776
Flight distance : 22530 ft
Question is does anybody know what distance you can be from Master Rc to Slave Rc and still be connected to aircraft from the Slave.
Lets say the slave is close to  a  tv with hdmi  could the slave be sending the video through the hdmi to t v and the master independent all together.
Sorry for the confusing question !
2016-5-18
terrylewis
Flight distance : 3517287 ft
The diagram in the user manual shows the dual controller communication the best:
Camera control signals travel via 5GHz from the slave to the master, but video returns from the aircraft to the slave via normal Lightbridge 2.4GHz.
So if the Slave can communicate with the aircraft, you can display the video via HDMI. It will depend on your signal strength between the aircraft and the remote controller...
2016-5-19
str1776
terrylewis Posted at 2016-5-19 05:51
Thanks Terry I will  test the video limits  for the slave  to aircraft distance  via feed to a HDMI larger monitor ( Big flat screen )
Basically what the diagram also points out you need both. The slave is a required connection  to  Master for  controlling camera got it . For viewing  only your on a separate frequency the slave  cool I like it.
Thanks Terry showing me its in the manual I'll work on distance  limitations .
2016-5-19
