Updating firmware and multiple batteries
931 8 2016-6-18
vipersl65
Flight distance : 31644 ft
So, if there is a new firmware update, I have to do this 3x ?  I mean , inserting a new battery each time and repeat the process 3x?
2016-6-18
jag01usn
yes, do each battery one time.
2016-6-18
vipersl65
jag01usn Posted at 2016-6-19 07:17
Thanks Joe.  I tried to insert another battery but it didnt do anything.  I was using DJI Assistant.
2016-6-18
jag01usn
Is the firmware on the sd card?  Just turn on the Phantom itself. Watch the battery Led's should flash for a few seconds or a little longer then the Led's go back to normal state. Battery update finished.
2016-6-18
vipersl65
jag01usn Posted at 2016-6-19 08:38
Is the firmware on the sd card?  Just turn on the Phantom itself. Watch the battery Led's should fla ...
Thanks Joe.  I was using DJI Assistant in my PC and the P4 is connected via the mini usb.  so not sure where the firmware is in that case
2016-6-18
maxxxpower1000
Hey guys, newbie question.........I bought my P4 about a week ago with 2 extra batteries If I'm following this right , you have to update the firmware with each battery installed in the P4? Really? I have used all the batteries at least once and I didn't do that. On my second flight I did see a firmware compatibility error, is there a way to check each battery? Did I miss a page of the book or something? LOL
2016-6-25
Heebus
when U get this error it will ask you if u want to update firmware, say yes n it will fix the battery, atleast it did this for mine... u should hear a critical battery lvl warning, or something like that, or again, atleast I did
2016-6-25
maxxxpower1000
That's exactly what happened, I thought it was the tablet, I had no ideas it was because of the battery.
2016-6-26
rodger
Flight distance : 20145135 ft
If you mean go through the entire update from the beginning to do each battery the answer is no. Do your update and then cycle each of your batteries through your Phantom. If there are any battery updates they will be applied to the individual battery.
2016-6-26
