Donnie
Flight distance : 3636782 ft
You will only have channels 13-20 on the Go App, unless you do the (Hack ) Upgrade to 32 channels . Are you sure you have the proper matching firmware ? Can you list them with everething on go to the "About Page " under General settings and list the versions here.
while you are just testing , make sure you are in Auto mode , this way the video can jump channels if you have problems, only use the Custom if you have the Updated 32 chan. file or you have a perfect channel that you like to stay with , for testing purposes use "Auto "
The I pad Air works great once we get you properly set up . I own the air as well. Make sure you have no other apps in the background running as well.
I think going with the I pad Air was good advise but we have to get the settings correct and make sure there is not something wrong with your system.
Is this a brand New Inspire with an X3 camera ? or X5
I am sorry you are having trouble , at this point can you list the hidden files so that we can see if there is corruption to the video file . If you have a PC it is easy to do and I will give you a link , I think you may have a damaged "Video Tranmission board" as I know that you have had Image challenges in the past.
I will leave a link to view the Hidden file and you want to lok at lines 0800 and 1500 for Update problems . or" Device not Detected "
Also in the past when I have talked to you, I suggested the I-pad air , but I hope it's not me you are referring to . And If it is I assure you I dont work for Apple . At this point with all the problems I think more than likely there is something more seriously wrong with your machine, and most likely will need to go in for service . Taht is why if you list the hidden file we can see if that is the problem.
And I am real sorry you are having troubles.
http://forum.dji.com/thread-44546-1-1.html
