Will this effect compass
John Hansey
Flight distance : 2026903 ft
Found this to work great for viewing tablet in bright sun.
Had no problem with distance, went 1260 feet out and all went well.
Will being surounded by car have any bad effect?
Sitting was a bonus also.
P3S
useing hatch to give viewing shade
2016-6-28
egconstruger
Flight distance : 26906 ft
Dominican Republic
can you tell me what firmware version you did? firmware 1.6.80 causing trouble to you?
2016-6-28
Geebax
As long as the aircraft is in front of you, you should be OK, could be a probelm if it flies behind you though. It will not affect your compass, because the compass is in the aircraft, not the RC unit.
2016-6-28
John Hansey
egconstruger@gm Posted at 2016-6-28 18:28
I'm not having any trouble.
Just found a way to see screen in bright sun.
2016-6-28
DJI-Paladin
Flight distance : 2408 ft
Hello John, as Geebax says, the compass is in the drone. So when the drone is flying in the air away from your car, you car will not influence the drone's compass.
2016-6-28
John Hansey
DJI-Paladin Posted at 2016-6-28 20:06
Hello John, as Geebax says, the compass is in the drone. So when the drone is flying in the air away ...
Thanks for the confirmation.
Got it no flying behind where the cars metal could compromise signal.
I was surprised how much the shade improved view on my IPad air2.
It even helped with line of sight view because over head shade!
2016-6-28
DJI-Paladin
John Hansey Posted at 2016-6-29 11:52
Got it no flying behind where the cars metal could compromise signal ...
You can do a simple search of this in our forum. I've seen some guys share their using experience in our forum.
2016-6-28
Airspace Explor
It may affect the compass of your mobile device.
If you have the compass unlocked in the DJI GO app so that the map view and the 'radar' feature orient to North regardless of the orientation of the MD, you may notice a difference. The only way to know is try it near the vehicle and then away from ferrous metal.
If you lock the compass, you'll see no difference near ferrous metal or not.
2016-6-28
FAS1
I do it like this all the time. No ill effects.
2016-6-28
