Osmo Audio In Slow mode
2177 3 2016-6-30
mdelbeck
Flight distance : 349111 ft
Just got my Osmo and tried the external mic that came with it. Turned on the audio within the app and my recordings are in slow motion (video is normal) also accompanied by a high pitched whine. Do I have a bad Osmo ???
here is a youtube link to sample WARNING: watch your volume ; high pitched whine
2016-6-30
DJI-H.C
Flight distance : 13602 ft
Hi, if you use the internal mic, is the voice lagging the same? (Most likely yes though).  It seems like the firmware you used is at fault, did you update the firmware when you receive Osmo?
Would you please try flashing the v1.6.2.10 firmware (again)?    You can find the download link and updating guidance here  http://www.dji.com/product/osmo/info#downloads
If the issue persists, you need to contact the seller you got it and ask for a return, which should be faster than returning it to DJI to repair.  If you have further questions, you can contact us through support@dji.com
Thank you.
2016-6-30
mdelbeck
Yup, that did it HC. Dummy me.! I knew that, that was a step I needed to do and I guess in my excitement at getting the Osmo in the mail, and playing with it,  that I thought I had done the FW upgrade.....I had not. Works beautifully! Thank you so much!
2016-7-1
DJI-H.C
mdelbeck Posted at 2016-7-2 09:04
Yup, that did it HC. Dummy me.! I knew that, that was a step I needed to do and I guess in my excite ...
My pleasure, glad it's working for your.
2016-7-4
