Lightbridge 2 Install HELP!
1695 13 2016-7-12
info.aerial-ins
Flight distance : 597487 ft
I am installing the Lightbridge 2 to a S900 recently purchased which was half built. Everything makes perfect sense apart from the gimbal cable. The Z15 gimbal on the S900 has a jack socket not a 7 pin connecttion.... How do I connect the gimbal to the lightbridge?
2016-7-12
DJI-Jamie
Flight distance : 112405 ft
To clarify, which gimbal are your using?
2016-7-12
info.aerial-ins
DJI-Jamie Posted at 2016-7-13 05:02
Zenmuse Z15-N
2016-7-12
DJI-Jamie
Unfortunately the Z15-N is not a compatible gimbal. The only compatible Z-15 gimbals are the Z15-GH4, Z15-5D III, Z15-A7, and the Z15-BMPCC.
2016-7-12
info.aerial-ins
DJI-Jamie Posted at 2016-7-13 05:11
Unfortunately the Z15-N is not a compatible gimbal. The only compatible Z-15 gimbals are the Z15-G ...
Looks like I need to reinstall the IOSD...
2016-7-12
DJI-Jamie
info.aerial-ins Posted at 2016-7-13 05:13
It is unfortunate, I apologize for the inconventience. This information was also available in the Specs section of both the Lightbridge 2's product page and manual.
2016-7-13
info.aerial-ins
DJI-Jamie Posted at 2016-7-13 18:33
It is unfortunate, I apologize for the inconventience. This information was also available in the S ...
Can I run Lightbridge 1 through the IOSD?
2016-7-14
DJI-Jamie
info.aerial-ins Posted at 2016-7-14 19:39
When using Lightbridge 1 with the iOSD Mark II, there would still be redundancies in OSD information, but you can still use the Mark II to record flight data for future analysis. You can still have them connected to the same rig without issue.
2016-7-14
Haga
Austria
DJI-Jamie Posted at 2016-7-14 17:16
When using Lightbridge 1 with the iOSD Mark II, there would still be redundancies in OSD informati ...
Hello!
I have Lightbridge2 installed with A2 on S1000+, unfortunately does LB2 Flight Unit not .. it lights up none of the two LEDs.
The following cables are connected:
- Gimbal cable, but without Gimbal
- CAN cable on CAN-distributor to A2 >terminal Can2
- Dbus cable A2> terminal X2
What could be wrong here, or is missing something?
Why are white and black antennas here with?
Can someone please help me further?
Thank's
2016-7-19
DJI-Jamie
Haga Posted at 2016-7-20 01:31
Hello!
I have Lightbridge2 installed with A2 on S1000+, unfortunately does LB2 Flight Unit not ..  ...
To clarify, you do not have a gimbal connected to your aircraft? Could you happen to provide a small video on the issue?
2016-7-19
Haga
Austria
DJI-Jamie Posted at 2016-7-19 21:27
To clarify, you do not have a gimbal connected to your aircraft? Could you happen to provide a sma ...
Sorry, Video is to large
Here are some photos ...
What type of connection gets the Lightbridge Unit the supply voltage?
2016-7-19
Haga
Austria
Haga Posted at 2016-7-19 22:52
What type of connection gets the Lightbridge Unit the supply voltage ???
2016-7-20
DJI-Jamie
Haga Posted at 2016-7-20 18:11
The air unit gets its power from the DBus connection. Could you clarify whether the unit is supposed to be on in these pictures? Unfortunately the computer image is not clear, what error message are you receiving in the Assistant Software? Is this your first time putting this unit together, or are you just upgrading your FPV system?
2016-7-20
Haga
Austria
DJI-Jamie Posted at 2016-7-20 16:04
The air unit gets its power from the DBus connection. Could you clarify whether the unit is suppos ...
No, that can not be right.
I have found that the power supply via the gimbal done. After I installed no Gimbal, there is no electricity. Is not well constructed :-(
2016-7-20
