Its my first thread on this forum and sadly its because a failure i have with my drone, well actually its battery.
Problem is that whenever i try to power on the battery (inside or outside the aircraft) it will just flash its 4 green leds altogether with the power on button and go back to 1 led and turn off.
I tried connecting one really small led to its output connectors and tried turning on the battery again, there is no power output at all.
I also tested it with multitested and there is really 0 output power from it.
This all happened out of suden when i was flying outdoors,
I had previously a decent 6minutes flight with drone and after i landed it safely and turned off to move onto next location I tried powering it ON again and drone didnt respond
I already tried the other batteries on my drone and they work just fine, and i tried charging the broken one and leds just do same thing as always (see video link attached)
VIDEO :
Please any DJI tecnician that could explain me what caused battery to "die" all of sudden ?
I mean the death of it is just my assumption as i already checked on all forums and there is nobody with same problem
What should I do to prevent this happening to my other batteries as I would be really pissed of if i lose any more
I dont feel bad for this one dying because I already used it for 2months now and had about 20 flights on it
Please hold the Fort! Someone will be with you when they wake up on the other side of the world. I am just an interested part of a holding pattern. Good luck with your battery problem. Hmm.
BTW, your English is excellent, so far. I keep my Google Translator warmed up for you South American guys - at least when I am awake!
Hello Zico,I'd suggest you to get in touch with our tech support via support@dji.com. This is possibly a hardware issue and sorry for the inconvenience.
Hi guys, well i am abroad now and i dont have access to net too much.
I will try to write to DJI Support team very soon.
I hope they can help me somehow.
Pd: I tried contacting them trough facebook page and no luck so far
