Phantom 4 gimbal looks at left
4168 20 2016-7-18
stefk1987
Flight distance : 518176 ft
Greece
After the latest update i have issues with the gimbal.. It is not looking at the centre anymore. It look a liitle bit to the left. What should i do?? My dealer does not exchange my one month old phantom4.
2016-7-18
DJI-Ken
Flight distance : 1515312 ft
perform a gimbal calibration.
2016-7-18
stefk1987
Greece
I have done 4-5 times gimbal cal. I calibrated the imu in a perfect level surface..
2016-7-18
DJI-Ken
stefk1987 Posted at 2016-7-19 05:20
Can you post a really quick video from the SD card.
2016-7-18
stefk1987
Greece
Ken do you want a video as i turn it on or during the flight?
2016-7-18
DJI-Paladin
Flight distance : 2408 ft
Hello stefk1987, have you tried to calibrate the IMU?
2016-7-18
stefk1987
Greece
Yes i calibrated in a totally perfect level. And gimbal calibration followed. Its about 1 degree looking at left
2016-7-18
stefk1987
Greece
Is there anything else you suggest me or should i send it to germany?
2016-7-18
DJI-H.C
Flight distance : 13602 ft
stefk1987 Posted at 2016-7-19 00:08
He means a video from the camera of the drone, while the drone is in the air. He's asking the video from the SD card of the drone, not the cached video  from your phone/tablet.
So he can assess how severe the tilt is
2016-7-18
stefk1987
Greece
The video is this. i could not put a straight line in the middle.
I can send you some other photos i took right now.
2016-7-18
DJI-Paladin
stefk1987 Posted at 2016-7-19 15:16
https://youtu.be/-mlgQr_mOMA
I can ...
The horizon is the video is level. At the end of the video, it is recommended to be easy on the sticks, which will make the view better.
2016-7-18
stefk1987
Greece
Ty Paladin. you dont recommend me to send it in for checking?
2016-7-18
DJI-Paladin
stefk1987 Posted at 2016-7-19 15:51
Actually there is no visible problem in your video.
2016-7-19
maxgajo
Flight distance : 20413 ft
Hi DJI-Paladin, the problem is not the vertical alignment but the horizontal alignement. If you look the camera from the top of the drone you can see that is looking 1 deg left although the position on the RC is centered. It is not easy to see from picture. As I have the same problem, I'll post a picture to se if you can understand as stefk1987 understood perfectly as we have the same problem... Am I worng stefk1987?
Max
2016-7-20
calmax
Mine has the same issue.  The camera/gimbal was perfectly centered before firmware update, but after firmware update, the camera/gimbal will point slightly to the left.  I thought something was wrong, so I exchanged to a new one, but the second one also did the same after firmware update.  Must be firmware problem??
2016-8-29
Yachtfilms
did u resolve your issue with gimbal?
2016-9-27
fans2053cede
Flight distance : 54803 ft
Malaysia
calmax Posted at 2016-8-29 13:37
I have the same problem also... Is it normal?
2017-1-7
TexasTurbo
Flight distance : 1172484 ft
fans2053cede Posted at 2017-1-7 07:33
return it there is a problem. My first p4 had this problem my second doesn't
2017-1-7
fans2053cede
Malaysia
TexasTurbo Posted at 2017-1-7 17:06
Thanks.. I will try contact them...
2017-1-7
calmax
The twisting method solved my off centered gimbal problem.
See This Link
2017-1-26
WindSoul
Flight distance : 16 ft
there is a way to straighten the camera. is a combination of C2 and right wheel. I never tried it so cant say how well it works. there is a youtube video.
2017-1-27
