zenmuse update x5 in matrice 600
4616 22 2016-7-21
piymamen
Flight distance : 456260 ft
Hi.  zenmuse not get update x5 in my matrice 600 . I try to follow the instructions inpire 1 and I can not update . can someone explain to me how this is done in the matrice 600 . a greeting
2016-7-21
DJI-Jamie
Flight distance : 112405 ft
This is your replacement X5 correct? Do you perform the X5 update on an Inspire prior to putting on the M600 or are you just trying to update it the same way?
2016-7-21
ftimster
Same here trying to update my new out of the box x5r on the Matrice 600 and it won't go... The FW reported in the app for the camera is 1.8.0.70?? What gives!!!
2016-7-21
piymamen
I NEED TO KNOW HOW UPDATES ZENMUSE X5 IN THE MATRIX 600.
2016-7-21
DJI-Jamie
piymamen@gmail. Posted at 2016-7-22 15:52
The X5 firmware is expected to be made available when the M600 is connected to the Assistant 2 Software. If you do not see the camera firmware currently, then it should be made available in the next software update.
Your only other way to update the X5 is via an Inspire 1 or OSMO. The SD card firmware method would not work with the M600 due to the extra data package for the wrong aircraft.
2016-7-22
DJI-Jamie
ftimster@hotmai Posted at 2016-7-22 12:57
Same here trying to update my new out of the box x5r on the Matrice 600 and it won't go... The FW re ...
Please refer to post #5.
2016-7-22
ronny5
Flight distance : 2177605 ft
Belgium
I dont know why you need the X5R update but my X5R gave no image when connecting it to the M600 (x5r came off my Inspire raw)
I got the x5r working on my M600 by making the "four button controller reset" then it started to work :-)
Works incredibly well on the M600 very stable and no need for afterstab. Flies for 30 min with std lipo!
Best Regards
Ronny
2016-7-24
userc9ef0845d1
need help !!
my setup is:
Big hexa frame with E-1200 (like a S900)
A3
LB2
X5
i cannot view video from X5 !
i test hdmi with gopro , GH4 , Alpha 5100 and work great but impossible to view X5 video
i can control X5 with LB2 , photo and camera trigger work
i put 50% EXT and 50% HDMI
100% EXT and 0% hdmi
ipad version dji go is 2.8.7
firmware are:
A3 1.3.0.00
LB2 air is 1.4.0.70+
Camera (upgraded on the inspire 1 pro) 1.9.1.10
radio LB is 1.15
all work but no X5 video ...
wirring seem's good , i check 5 times all wire
2016-8-24
DJI-Jamie
userc9ef0845d1 Posted at 2016-8-24 23:01
need help !!
my setup is:
Just to clarify, do you have your unit set up for PIP, or do you only have the X5? Does the X5 seem to be receiving power? What kind of LED indicators are you getting from the camera and Lightbridge 2?
2016-8-24
Black-Raiser
when i sellect LB , i can see the video from hdmi (gopro 3b+) and Lb2 led is green , all work fine
but when i select EXT to see the X5 video , LB2 led is red fixe and no video
2016-8-25
fansca831033
Hi.  zenmuse not get update x5 in my matrice 600 pro . I try to follow the instructions with sd card  and I can not update . can someone explain to me how this is done in the matrice 600 pro . The camera work good but I can't fly because the remote control shows firmware upgrade with camera in matrice 600 pro, Without camera the remote control shows no upgrade.how can I upgrade the X5.   Thanks
2017-2-18
ricci2
Flight distance : 61158 ft
Hi,
X5 is updated via the assistant2 software, if it need to be updated it will show there. I see its mentioned in the thread above, No.5
ricci
2017-2-18
fansca831033
ricci2 Posted at 2017-2-18 04:02
Hi,
Hello Ricci, with assistant 2 I only see the m600 update and lightbrige 2 update, Where I found the x5 update. Thank you.
2017-2-18
ricci2
Hi,
My X5 has the latest update and I did not do anything to load the firmware except the assistant2 link. I am now on 1.10.1.40 and was on the 1.10.1.30. I can assume the camera F/w is bundled with the A3 F/w or the LB2 f/w.
if your f/w is 1.40 then you are up to date. if not make sure to do any update you see on the assistant 2. one thing I did when the go app said firmware was available was to roll back the f/w to the previous, then in assistant 2,  put the latest on again, it worked for me and the reminder went away.
hope that helps.
ricci
2017-2-18
fansca831033
ricci2 Posted at 2017-2-18 14:29
Hi,
Thank you i will try that.
2017-2-18
ricci2
fansca831033 Posted at 2017-2-18 15:19
Hi,
Did you get your camera to update, I hope so.
Ricci
2017-2-26
Southard227
I am in a similar issue as fansca831033. The DJI GO app says there's a Firmware Update Required. However, according to the DJI Assistant 2 App, both the Lightbridge 2 and Matrice 600 Pro firmwares are up to date. No other products are listed. I have tried following the DJI's Youtube tutorial as far as updating the X5, but whenever I boot the drone, the camera seems to ignore the .bin file on the Micro SD card (it is located in the root directory.) When checking the log files, there's not a post-update .txt file saying failure or success. Only the OSMO_FC550_CAM_VERSION file, containing "ȯ" and the file hasn't been modified since 1/1/2014.
I have attempted rolling back the Lightbridge 2 to V1.0.1 and then back to V1.1.50, but to no avail. I can't rollback the M600 Pro firmware as the only version available is V1.0.0.80.
Version Numbers are:
App 3.1.4
Aircraft 1.0.0.80
Remote Controller 1.2.00
Camera 1.9.1.10
LB2 Air 1.1.50
Thank you
2017-2-27
ricci2
Southard227 Posted at 2017-2-27 07:27
I am in a similar issue as fansca831033. The DJI GO app says there's a Firmware Update Required. However, according to the DJI Assistant 2 App, both the Lightbridge 2 and Matrice 600 Pro firmwares are up to date. No other products are listed. I have tried following the DJI's Youtube tutorial as far as updating the X5, but whenever I boot the drone, the camera seems to ignore the .bin file on the Micro SD card (it is located in the root directory.) When checking the log files, there's not a post-update .txt file saying failure or success. Only the OSMO_FC550_CAM_VERSION file, containing " ȯ" and the file hasn't been modified since 1/1/2014.
I don't know if you have a osmo? but this is how I first put the updated F/W on, I used the pro F/W.
Cant think how to do it any other way, why don't you pm DJI Jamie, he's very helpful.
Ricci
2017-2-27
DJI-Jamie
I had notified the proper team to make it available through the M600 Pro series. At this point, you can see if you can get ahold an Inspire 1, M600 or OSMO, you can update it that way. A dealer would be able to help you out if you need something more local.
2017-3-3
Ronny G
Sweden
userc9ef0845d1 Posted at 2016-8-24 07:01
need help !!
my setup is:
I had the same problem with no image from X5R on M 600 with LB2
Found out when switching from Ronin to x5r and a lot of updates later i had to change these settings in the Go app
Bandwith allocation to something like 50%
App output mode to EXT
Then image Ok :-)
2017-5-15
Erin Radford
DJI-Jamie Posted at 2017-3-3 00:07
How do we update the X5 with the M600?
I've tried the SD card method so many different times and it won't work.
Please, I'm desperate, I'm booked all week with jobs & I cannot get the camera to run normally.
2017-7-31
Balchindorj
Mongolia
Hey guys,
I had same problem updating the Zenmuse X5 with the M600. Couldn't update with the SD card. Someone please help.
2017-8-4
ROV Concepts
Flight distance : 5801 ft
Did anyone get a fix for this ?
2018-11-12
