sales58
Sent this to DJI support, looking to see if anyone else if having this issue?
---->Link to video showing issue <----
As you will see in the video all is set up correctly, the A3 just doesn’t want to control the ESC/Motors via the “test motors” or arm thru the Futaba. I have set up dozens of Wookong’s and A2’s - I must have gotten a lemon A3, should not be this difficult?
Tested with KDE 5215 430 KV motors / KDE 95 ESC's & Tiger U7 490 KV / Tiger 80 ESC's - both drones do not arm or activate motor test - they do have signal since they do not beep contuniously after boot up.
The software did crash a number of times on the firmware update due to a faulty DJI supplied USB, maybe something got corrupted because weird things happened like:
- Bad USB cable:
would hang or fail with both firmwares available
would hand or fail at 98%
- Once I figured out the USB cable issue it updated to the latest firmware 1.3 BUT...
every once in a while on boot up, got errors stating either compass or IUM was disconnected and to redo - i’d replug it in an all is good but happened a few time which is unsettling.
Thanks, Jason
