prop problem???
1154 5 2016-7-23
byrneshaun4
hi, guys, i fitted some quick lock props to my inspire yesterday and when i tryed to take off the whole aircraft started shaking and wouldnt lift, i fixed them to where i thought was the right places, on the front red on left and white on right as you look at it and opposit on the rear,
        any thoughts guys
2016-7-23
markaguille
Flight distance : 2031818 ft
Guernsey
Can you post some pictures? Are they genuine DJI props and where did you get them?
2016-7-24
Donnie
Flight distance : 3636782 ft
When facing the Aircraft the Right prop should be Red and the left Prop White and the  back section of the aircraft would have a White  prop on the Right and a White Prop on the left,.
The Red prop, and white Props are in a X pattern , so they are diaganol from one another.
I am sure that your problem is your props are in the wrong spot .
Like my diagram below with the "C" being the Camera and The R And W for White and Red of course.
R         W
W    C      R
2016-7-24
Alastair
Flight distance : 96631 ft
Is it possible you're not getting enough throttle because of a bad RC calibration?
2016-7-24
byrneshaun4
Alastair Posted at 2016-7-24 14:32
plenty of throttle, put the spin on props on and it was fine, thanks for your reply
2016-7-24
byrneshaun4
Donnie Posted at 2016-7-24 13:26
When facing the Aircraft the Right prop should be Red and the left Prop White and the  back section  ...
thanks donnie that done the trick, they were original dji props and fixings with no instructions, but i should have noticed the pitch of them, thanks
2016-7-24
