Strange pixels in video
1381 18 2016-8-11
marcelvanderwer
Flight distance : 765233 ft
Hello
I discovered some problems in the footage i'll made.
This is a screenshot i'll made from the footage, as you can see there are soms half rings in the sky, i'm wondering what this is and what is the possible cause? Is it a setting?
It was shot in 4 K
D-log
25 fs
sunny conditions , no wind I used a ND- filter 3 stops,
aperture  f/11 (or higher i'm not shure)
iso 100
DJI standard lens
Afther this shooting i did some more jobs and everything looked very good, so i think the camera is oke.
Hope you can help me to prevent it wil happen again.
Kind regards Marcel
sky pixels
sky pixels
2016-8-11
DJI-Jamie
Flight distance : 112405 ft
Unfortunately the picture you provided is a tad small and bright. Do you have a larger or slightly darker version?
2016-8-11
marcelvanderwer
DJI-Jamie Posted at 2016-8-11 18:05
Unfortunately the picture you provided is a tad small and bright. Do you have a larger or slightly d ...
Dear Jamie, Thanks for your reply, i up loaded the video to VIMEO, i'll hope the resolution is good, if not, please let me know so i can send you a download link
Here is the link:
The password is: sky
Hope you know what caused this effect.
Thanks Marcel
2016-8-11
DJI-Jamie
marcelvanderwer Posted at 2016-8-12 01:21
Dear Jamie, Thanks for your reply, i up loaded the video to VIMEO, i'll hope the resolution is goo ...
I can see it better, thank you. Which Inspire model do you have? To clarify, are you using a DJI ND filter or a 3rd party filter? Do you notice this with various filters or just this one? Have you tried wiping down the lens and filters to ensure they're clean? How long have you had this unit?
2016-8-11
marcelvanderwer
DJI-Jamie Posted at 2016-8-11 20:11
I can see it better, thank you. Which Inspire model do you have? To clarify, are you using a DJI N ...
I have : Model T600  (with X5 camera)
Using a Polar pro ND8 filter (3 stops)
Do you notice this with various filters or just this one? I have to test it this weekend
Have you tried wiping down the lens and filters to ensure they're clean? yes i'll do that before every fligth
How long have you had this unit? : I'll bought this unit on 20th may.
2016-8-11
DJI-Jamie
marcelvanderwer Posted at 2016-8-12 13:05
Do you recall if this occurred after a firmware update, or once you started using specific filters. Try taking some pictures without a ND filter as well, so that we can rule out an issue with the X5 itself.
2016-8-12
marcelvanderwer
DJI-Jamie Posted at 2016-8-12 17:43
Do you recall if this occurred after a firmware update, or once you started using specific filters ...
I did some  testing and here are my findings.
I dont now if it happend after the update.
My conclusion after testing (a lot of settings) is:
It has nothing to do with the ND filters.
It only happens when recording in d-log, doesn't matter what settings i use
in No colour profile it looks oke
Is it a problem with the camera or a software problem?
2016-8-16
DJI-Jamie
marcelvanderwer Posted at 2016-8-17 02:20
After further digging, this is an effect that can occur in D-Log when it's over exposed. The semi circles are the various degrees of exposure when combind with the ever changing light from the sun. Try reducing the exposure a bit and see if the lines are less apparent. You can also try running it through the Inspire 1/ Phantom 3/ X5 LOG mode Transcoding Tool to clean it up.
2016-8-16
marcelvanderwer
DJI-Jamie Posted at 2016-8-16 23:52
After further digging, this is an effect that can occur in D-Log when it's over exposed. The semi  ...
Thanks for your help Jamie, i'm going to try it today.
2016-8-16
DJI-Jamie
marcelvanderwer Posted at 2016-8-17 12:40
Let me know if there are any changes.
2016-8-17
marcelvanderwer
DJI-Jamie Posted at 2016-8-17 16:16
Hi Jamie,
Today we had a shooting with a beautifully  clear blue sky , unfortunately in D-log the circles where still there:-(
There was absolutely no over exposure. We used a 3 stops ND fiilter to manage the diaphragm/ exposure  (f5.6 or f8).
I tried the transcoding tool but it would not help.
We viewed the files in Edius and Da Vinci resolve.
We also did some shooting without a colour profile everything looks perfect. so i don't understand what's wrong with the d-log. I'm thinking of downgrading to a previous version of the firmware of the Inspire to see if the effect is still there.
Do you have any other suggestions?
Kind regards Marcel
2016-8-17
DJI-Jamie
marcelvanderwer Posted at 2016-8-18 02:33
Hi Jamie,
Today we had a shooting with a beautifully  clear blue sky , unfortunately in D-log the  ...
Is the effect just as prominents as in the initial picture or is it less? Downgrading would rule out whether it's a hardware or software issue with the X5.
2016-8-18
marcelvanderwer
DJI-Jamie Posted at 2016-8-18 23:39
Is the effect just as prominents as in the initial picture or is it less? Downgrading would rule o ...
It's is the same, i see not any difference. I found also some (D-log) footage before i did the firmware update.
I think the only option left is to go to my DJI dealer.
2016-8-19
DJI-Jamie
marcelvanderwer Posted at 2016-8-19 18:55
It's is the same, i see not any difference. I found also some (D-log) footage before i did the fir ...
Just to be clear, the effect was not prominent prior to the firmware update?
2016-8-19
marcelvanderwer
DJI-Jamie Posted at 2016-8-19 18:32
Today  i went back to firmware version 1.8.1.00
Unfortunately the effect is still there. When i choose 'no color profile' it looks better but its still there.
I think we ruled out software and some hardware components. Do you have   advise for me Jamie?
2016-8-26
marcelvanderwer
I uploaded a new video today (shot in HD 50 fs and d-log.) i'll hope someone recognise this problem.
Regards Marcel
2016-8-26
Tahoe_Ed
Flight distance : 2605 ft
Please try none vs dlog.  See if that helps.
2016-8-26
DJI-Jamie
marcelvanderwer Posted at 2016-8-27 01:04
I uploaded a new video today (shot in HD 50 fs and d-log.) i'll hope someone recognise this problem. ...
This may be a behavior that is specific to D-Log. I have passed this information along to the R&D team for further review. At this time, you may want to move to using the "None" option, as it will provide multiple post production options as well.
2016-8-26
marcelvanderwer
DJI-Jamie Posted at 2016-8-27 00:31
This may be a behavior that is specific to D-Log. I have passed this information along to the R&D  ...
Thanks Jamie, i must say i also see it a little bit in the non colour profile.
Please keep me posted
2016-8-30
