mike_71
Flight distance : 277057 ft
Hi all, I have a new Phantom 3 Advanced, I fly it with an ipad air 2 I bought for the task. I have 2 batteries. Everything is running 1.9.60 and 1.60 the latest firmwares. I am having an issue since I got it where it gets stuck in IMU calibration. Also it tells me the firmware on the aircraft is Unknown version and needs to be upgraded, also tells me the remote firmware is unknown version and needs to be upgraded randomly. However the 2 issues dont always coincide but usually do.
I will turn on the quad, it does its power up things, it says home point updated and i have 15 gps sats, and are in p-gps mode and then i do the CSC and it tells me IMU calibration in progress dont move the aircraft until complete. And it will continue to do this doesnt matter how long I wait. I managed to get it working once by turning everything off and back on a couple times but usually it doesnt work, I end up going home, then when I go back the next day it usually works ok.
When it does fly it flies great and doesnt seem to have any issues at all, really impressive when it flies.
Any ideas what I can do? If the drone is defective I need to figure that out asap as the return window ends soon from Amazon. Seems more like a firmware issue than hardware to me but I ahve no idea.
BTW, when it says that message about IMU calibrating in the top left corner of the screen in yellow, if I go to the P-GPS tab it says IMU status is green/ok.
Thanks
EDIT: I was saying IMU Calibration but i believe it actually said IMU initilization.
