Aardvark
Flight distance : 384432 ft
What you're getting on the tablet is a live 720P feed from the aircraft, which is subject to interference. So may be partially due to that.
"Problem I have is I have nothing in my house that will show 4k "
No need for a 4k display although nice. You can record in 4k and playback software can resize to 1080P or whatever for display on a non 4k screen. With a video editor you can also record in 4k and render it to 1080P which works out well.
But you still need a fairly new computer to be able to play back 4k smoothly.
There is also one other thing to consider if using an Android device, and that is to check the state of the USB port. For older (and possibly newer) devices, USB Configuration needs to be set to MTP (Media Transfer Protocol). This certainly worked for cleaning up the display on the Nexus 7 MkII that I used to use. The downside as far as I remembered was that it had to be manually set each time, but this may have changed.
